586,060 active members*
3,494 visitors online*
    Work offsets shift on sinumerik 828D
    Hi. I'm trying to shift the work offset in a program. I have tried using g10 g50 g52 g92 but none of them are supported by the controller. What else can I try? I guess I could change the machine variables directly, but this seems risky. Or I can add an x, y and z variable to all the coordinates in the program, but that is very tedious and I rather not. Any ideas? Thanks.
    Aug 2009
    1573
    Re: Work offsets shift on sinumerik 828D
    Coordinate transformations (frames)
    From Siemens manual......
    Settable frames are the configurable zero offsets which can be called from within any NC
    program with the G54 to G57 and G505 to G599 commands. The offset values are predefined by
    the user and stored in the zero offset memory on the controller . They are used to define the
    settable zero system (SZS).
    See:
    ? Settable zero system (SZS) (Page 30)
    ? Settable zero offset (G54 to G57, G505 to G599, G53, G500, SUPA, G153) (Page 149)
    https://www.google.com/url?sa=t&rct=...o2JeKLLX1qoPxw
    That's it. Thanks a lot. Simply trans z-18 does it.
  1. Doosan Lynx220LSY Sinumerik 828d TLM
    By tomasra19 in forum Daewoo/Doosan
    Last Post: 02-25-2018, 09:49 PM
  2. Siemens 828D control work offsets
    By deegeeceeoz in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-28-2016, 04:53 AM
  3. g-code for sinumerik 828d problem
    By xray34 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-28-2014, 01:23 AM
  4. g-code for sinumerik 828d problem
    By xray34 in forum G-Code Programing
    Last Post: 09-17-2012, 09:51 PM
  5. edgecam > sinumerik 828d problems
    By xray34 in forum EdgeCam
    Last Post: 09-16-2012, 01:41 PM
