586,070 active members*
3,517 visitors online*
    Jan 2019
    Meldas M320V with a Hartford HV-35
    Hello,
    A couple of months ago I bought a used Hartfort HV-35 with a Mitsubischi Meldas M320V control.
    The milling machine has stood still for a couple of years.
    After I installed the Hartford and turn on the power there were a couple of error’s.
    The machine has not lost its parameters only a couple of PLC standard’s.
    The drive was broken and I send it away for repair.
    Now the machine will start up and can make some move’s, the tool changer works perfectly.
    It will mill straight lines but when I try to make round corners the error “ P70 ARC ERROR “ comes up.
    I made a straight forward program to mill a square of 30x30mm and I ad later the round corners of R=3mm, all with a mill ø6mm without radius compensation.
    I need help to get me around the corner. What do I forget and are there some Parameters that can make the change.
    I have all the original books and Parameter list’s but I can not find anything.
    Please help.
    Mark
    Jan 2019
    Re: Meldas M320V with a Hartford HV-35
    Some picture's
  1. Meldas M320V parametters
    By homejonny in forum Mitsubishi controls
    Last Post: 12-23-2018, 05:06 PM
  2. Hartford lg1000 vmc
    By Al4350 in forum Australia, New Zealand Club House
    Last Post: 10-10-2018, 10:29 PM
  3. hartford vmc1000+cnc meldas retrofit can ?
    By massimo38 in forum Controller & Computer Solutions
    Last Post: 04-12-2015, 04:40 PM
  4. hartford
    By jamesrnz in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2009, 12:03 AM
  5. Hartford CNC
    By phc in forum Bridgeport / Hardinge Mills
    Last Post: 06-19-2006, 07:01 PM
