586,069 active members*
3,847 visitors online*
Thread: G320X Users
Results 1 to 2 of 2
    Oct 2008
    2100
    G320X Users
    Ok, who has G320X drives that have been in service (used atleast a couple times a week) for more than a couple years?
    What voltage and current are you run through them?
    Did you install that dump circuit that GeckDrive suggests you build and install?
    Are they still performing the same as when you first installed them?
    Bob La Londe
    http://www.YumaBassMan.com
    Dec 2017
    10
    Re: G320X Users
    I use them to drive a couple of fanuc 5m and one 10m fanuc dc servos for one and a half year whitout any problem on the drives, using non regulated 63 VDC supply, current setting 90% of the max. Encoders are the amt´s 102 v, not using dump circuit, max rapids 180 ipm. Machine is an old Bridgeport VMC 520. The only change i need to made was install linuxcnc in replacement of mach 3 . Never got to tune mach3 for real reliability when i ran the machine few hours whitout stop. Until now the drives perform rock solid.
  1. G320X Tuning..
    By lancut in forum Gecko Drives
    Last Post: 01-31-2017, 04:32 PM
  2. G320X problem
    By CS900 in forum Gecko Drives
    Last Post: 06-21-2013, 12:35 AM
  3. G320X MANUAL
    By mayo in forum Gecko Drives
    Last Post: 04-27-2013, 04:51 AM
  4. Another G320X question
    By w7bcw in forum Gecko Drives
    Last Post: 04-03-2013, 08:14 PM
  5. G320X PID
    Last Post: 04-03-2013, 03:14 PM
