586,108 active members*
3,208 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Rs232 problems 88hs
Results 1 to 8 of 8
    Jan 2010
    321
    Rs232 problems 88hs
    Peeps
    Can't communicate with my 4020 that we purchased at auction . I have another fadal so have tried swapping some bits
    I have tried the following to 1030-1c
    2 known good pc
    2 know good cables from pc to vmc.
    Swapped the rs232 cable from the cab to the 1030 board
    Removed the card cleaned contacts with a rubber and installed.
    Replaced both the 1489 and 1488 chips on the 1030 card.
    Still nothing.
    The only thing I haven't changed is the 1030 card.
    My other fadal has a 1030-1 card with a different suffix maybe a 'b'
    Can they be interchanged safely?
    Aug 2009
    1573
    Re: Rs232 problems 88hs
    Local for you maybe..down under
    https://www.ebay.com/itm/fadal-PCB-0...4AAOSwCgJcmvii
    gambling tosave a few dollars...for sure.
    If, I remember correctly these guys answered all my questions and than sum on the phone...10 years ago.
    https://itscnc.com/cnc-boards-1030-c...ec8244cca7c358
    Sep 2011
    110
    Did you look into the setting of the RS232 communication, the odd/even, the bit number and the rate?
    Jan 2010
    321
    Thanks.
    Yes looked at the setting tried a few different baud rates also
    Jan 2010
    321
    Also maybe worth noting the other 1030-1b card in our other machine is without video. I believe these were available both with and without video.
    The 1030-1c card we are having issues with is also without video.
    I suspect they will be interchangeable but want confirmation prior is anyone knows?
    Jan 2010
    321
    I heard from ITS that they are interchangeable. I swapped the cards and rs232 works so the fault lies with my 1030-1c card.
    I will send off for repair.
    Cheers
    Feb 2007
    171
    Sir, there is an RS232 Troubleshooting guide I can send you which includes a test for your communications board. If you get your board back and your communications is still not working, contact me at [email protected] and I will send you the troubleshooting guide so we can pinpoint exactly what is going on. I have dealt with RS232 problems for years and know exactly what you need to make it work. I will help if you need any further assistance.
    FadalCNC Tech Support
    Sep 2010
    6
    Greetings, this is Jerry at Highland DNC. ShopLink FLASH 2.0 is your hand held solution to RS232 file transfers.
    Sold over 2500 units used on mostly Haas and Fadals, also Fanuc, Yasnac, Mazak, and many others.
    The windows pc is now ill suited for RS232 for many reasons. Everyone knows how to use a flash drive and get a gcode file on one.
    Then transfer it to the Fadal using the TA or DNC command through ShopLink FLASH 2.0.
    I can SEND, RECEIVE and DNC a file up to 2000 megabytes.
    Just google ShopLink FLASH 2.0 and contact me and I will explain everything.
  1. RS232 problems on T32-3
    By pool411 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-29-2017, 08:51 PM
  2. RS232 Problems
    By mavalos in forum USB, RS232, PARALLEL etc
    Last Post: 06-04-2013, 03:45 PM
  3. rs232 problems
    By owassomachine in forum Bridgeport / Hardinge Mills
    Last Post: 08-25-2009, 09:43 AM
  4. Rs232 Problems
    By j-radkemachine in forum Haas Mills
    Last Post: 05-09-2007, 09:21 PM
  5. Problems you have or had with RS232?
    By gar in forum Polls
    Last Post: 12-22-2005, 05:21 PM
