586,337 active members*
3,697 visitors online*
    Mar 2012
    T01 can cycle st 0104, Meldas 50
    Dears
    I have "T01 can cycle st 0104" and this is my problem. On manual mode everything working fine, but when i set MDI mode and press for examply: S500; and press CYCLE START, on display i have error message "t01 can cycle st 0104". The same is when i try to start program from memory. I check all wirles and looks fine. ON PLC Y219 is set 0, propably should be 1
    I found propably "X26E PCNT" is set 1 and should be 0. I need to know what is PCNT, and how to turn off. I will be grate full for any help
    Best Regards
    Pawel
    Poland
    Sep 2017
    139
    Re: T01 can cycle st 0104, Meldas 50
  1. Mitsubishi Meldas 600M control won't run G83 peck drill cycle
    By mscav219 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-08-2018, 04:30 PM
  2. Replies: 0
    Last Post: 02-02-2017, 04:08 AM
  3. CYCLE 83: pecking cycle with deepened starting point
    By Bastida in forum SIEMENS -> GENERAL
    Last Post: 12-18-2011, 04:25 PM
  4. Heidenhain iTNC 530: Using Cycle 19 and Cycle 8
    By Dan B in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2011, 05:32 PM
  5. Meldas 50 lathe T01 CAN'T CYCLE START 0104
    By GPena in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-15-2008, 04:02 PM
