586,103 active members*
3,278 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > SINGLE START AND DOUBLE START NUT
    Hi, I am newbie
    I've got problem with my ball screw and nut set I bought from a supplier, I cannot install nut into ball screw, it stuck in the first lap then balls drop.
    The screw is 20mm diameter, 10mm lead double start, but the nut has only 1 groove with 1 return, is it single start nut?
    Is there any case a single start nut can match a double start ball screw?
    Sorry I am not good at English, thank you very much
    Jun 2011
    692
    Re: SINGLE START AND DOUBLE START NUT
    I think a 20mm lead single start could work with a 10mm lead double start, but could only transmit half the force (one of the starts wouldn't be used.)
  1. Need 1/2in 10 tpi single start acme leadscrew
    By Momentz in forum Australia, New Zealand Club House
    Last Post: 10-04-2011, 04:00 PM
  2. Double start thread program help
    By himatech in forum NCPlot G-Code editor / backplotter
    Last Post: 12-24-2010, 03:02 AM
  3. HELP -- ACME .125 pitch with double start clipped
    By Condor-mac in forum G-Code Programing
    Last Post: 06-24-2010, 06:35 AM
  4. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
