586,103 active members*
3,183 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Techno CNC > Tool diameter compensation on a Techno CNC machine
    Hello guys, first time posting here.
    English isn't my first language so I'll try my best.
    I was wondering if it is possible to setup (on the CNC software) an offset, or compensation value for the tool diameter.
    We are using 0.500'' tools. The fact is that when we get the tools sharpened, the diameter gets smaller as much as 0.475''.
    Programs are generated in a program named Microvellum and the tool diameter is set in there.
    I would like to be able to change something into the CNC software instead of having to reprogram my jobs everytime I change a tool.
    Is it doable with the Techno CVC software (BUILD #400)?
    Thanks!
    Re: Tool diameter compensation on a Techno CNC machine
    Does it support G41/G42?
    Sep 2012
    215
    Hello,
    The newer versions of the software have this ability. Contact us at Armor CNC - contact page - to discuss.
    Your CAM software has to put out the proper G41/42/43 commands to take advantage of it.
    Regards,
    Eric
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
  1. Tool diameter compensation G41/G42 Post processor
    By djcregan in forum PhotoVCarve and VCarve Pro
    Last Post: 04-12-2018, 01:46 AM
  2. General question on tool diameter compensation
    By rzugnoni in forum Uncategorised MetalWorking Machines
    Last Post: 02-05-2015, 10:54 PM
  3. Replies: 3
    Last Post: 05-12-2014, 02:50 PM
  4. .dxf to g-code converted with tool-diameter compensation?
    By cnczoner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-16-2007, 01:31 PM
  5. Any Info On Tool Diameter Compensation?
    By FLUTE HEAD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2004, 11:02 PM
