586,058 active members*
3,389 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Aug 2010
    686
    CNC Construction Set Build 4 Blog
    I totally dismantled the CNCCS prototype. Many of the parts are the same as used on the current builds, so I decided to do a new build from scratch so that I could utilize these parts.
    On this build I am going to go with aluminum on the plate material. My goal is to do this without any special machining gear. IE pretty much using a drill press.
    Before I get started I wanted to show you my layout since you will see much of it in the background of this build.
    My shop/lab is divided into six 12" x 12" sections. I label them 1-6 with 1 being the 12x12 section at the double door entrance to my shop.
    The section I will be using for this build is section 2 shown here.
    Attachment 418084
    Currently this shop section contains:
    30" shear, break, slip roller
    CNCCS Build 3 with downdraft vent and plasma cutter
    TIG Welding Workstation
    Extra CNC PC
    6-Ton Press
    20-Ton Press
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Aug 2010
    686
    Re: CNC Construction Set Build 4 Blog
    Volume 1 - Chapter 1 - Frame and Carriages
    Frame installed and attached to the stand.
    Attachment 418086
    I opted to go with the heavy duty leveling casters.
    Aug 2010
    686
    Volume 1 - Chapter 3 - Y Rails
    Anything that is not aluminum, I will be painting flat black on this build.
    Aug 2010
    686
    Volume 1 - Chapter 4 - Y Carriages
    This is where I had to make the first aluminum adapter plate.
    Attachment 418094
    Attachment 418096
    You can see the Y carriage adapter plate write-up here:
    https://www.kronosrobotics.com/cnccsycarriageplates
    Aug 2010
    686
    Volume 1 - Chapter 5 - X Rails
    X rails installed on gantry.
    Aug 2010
    686
    Volume 1 - Chapter 6 - Gantry
    Gantry Installed.
    Link to the the aluminum gantry riser write-up can be found here:
    Gantry Risers — Kronos Robotics
    Aug 2010
    686
    Volume 1 - Chapter 7 - Gantry Brace
    Gantry brace installed.
    Attachment 418102
    Aug 2010
    686
    Volume 1 - Chapter 8 - X Carriage
    X Carriages Installed.
    Attachment 418104
    Volume 1 - Chapter 9 - Z Rails
    Z Rails Installed.
    You can see my aluminum X carriage write-up here:
    https://www.kronosrobotics.com/cnccsxcarriage
    Aug 2010
    686
    Volume 1 - Chapter 10 - Z Carriage
    Aluminum Z carriage installed.
    Note that I went ahead and removed the X carriage from the machine and placed it on the table. Its going to be removed again real soon anyway.
    My write-up for the aluminum Z carriage can be found here:
    Z Carriage Plates — Kronos Robotics
    Aug 2010
    686
    Volume 2 - Chapter 2 - Tuning the Gantry
    Gantry tuned.
    Volume 2 - Chapter 3 - Work Table
    Temporary work table installed.
    Aug 2010
    686
    Volume 2 - Chapter 4 - Tuning the Z Carriage
    Z carriage Tuned.
    Attachment 418862
    Volume 2 - Chapter 5 - Pen Holder
    Pen holder installed.
    Attachment 418864
    Volume 2 - Chapter 6 - Squaring the Gantry
    Gantry is square.
    Attachment 418866
    Aug 2010
    686
    Volume 2 - Chapter 7 - Y Drive Plates
    Y drive plates installed.
    You can see my Aluminum Y drive plate write-up here:
    https://www.kronosrobotics.com/cnccsydriveplates
    Aug 2010
    686
    Volume 2 - Chapter 8 - X Drive Mounts
    Aluminum X drive Mounts installed.
    Attachment 418870
    See the Aluminum write-up here:
    https://www.kronosrobotics.com/cnccsxmotorplates
    Aug 2010
    686
    Volume 2 - Chapter 9 - Y Drive Mounts
    The aluminum Y axis bearing and motor mount plates are installed.
    Attachment 418872
    Here is the write-up for creating the aluminum plates.
    https://www.kronosrobotics.com/cnccsmotorplates
    I also have a video of the process here:
    Aug 2010
    686
    Volume 2 - Chapter 10 - Z Drive Mounts
    Z Drive mounts installed.
    Attachment 418874
    See my write-up here:
    https://www.kronosrobotics.com/cnccszmotorplates
    - - - Updated - - -
    Volume 2 - Chapter 11 - Z ACME Screw
    Z axis ACME screw installed.
    Aug 2010
    686
    Volume 2 - Chapter 12 - X Axis ACME Screw
    X Axis ACME Screw installed.
    I did have an issue with this bolt holding the gantry riser.
    I had to grind about 1/16" off to keep it from hitting the bearing block.
    Aug 2010
    686
    Volume 2 - Chapter 13 - Z Carriage Install
    Z Carriage Installed with ACME screw.
    Aug 2010
    686
    Volume 2 - Chapter 14 - Y ACME Screws
    Y ACME Screws installed.
    This completes Volume 2. Next, I will be starting Volume 3B, Advanced Electronics.
    Aug 2010
    686
    Volume 3 - Chapter 2 - Advanced Layout Board
    Layout board complete.
    Volume 3 - Chapter 3 - Mounting the Power Supply
    Power supply mounted'
    Volume 3 - Chapter 4 - Mounting the G540
    G540 mounted.
    Volume 3 - Chapter 5 - Mounting the Terminal Blocks
    Terminal blocks mounted.
    Volume 3 - Chapter 6 - Basic Wiring
    Basic wiring complete.
    Attachment 418892
    I went ahead and added the accessory brackets and mounted my layout board on the side of the machine.
    Aug 2010
    686
    Volume 3 - Chapter 7 - Mounting the 12V Regulator
    12V regulator mounted.
    Volume 3 - Chapter 8 - Mounting the 5V Regulator
    5V regulator mounted.
    Volume 3- Chapter 9 - Mounting the UC300 Motherboard
    Motherboard mounted.
    Volume 3 - Chapter 10 - Advanced Wiring
    Advanced wiring completed.
Page 1 of 2 12
  1. CNC Construction Set Build 3 Blog
    By msimpson99 in forum Uncategorised WoodWorking Machines
    Last Post: 04-16-2019, 11:20 PM
  2. New Design/Build: CNC router (steel plate construction) + Raspberry Pi
    By cmadki4 in forum DIY CNC Router Table Machines
    Last Post: 09-24-2017, 03:11 PM
  3. Replies: 4
    Last Post: 07-24-2013, 11:48 AM
  4. DIYLILCNC PVC Build - Bed Construction
    By jimmycakes in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 05:58 PM
  5. 9'X5.5' Router table - Build Blog...
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 09-13-2007, 04:20 PM
