586,043 active members*
3,812 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Face cutting 2 inch carbon steel bar stock
Results 1 to 12 of 12
    Jan 2011
    129
    I need to remove 1/4 inch of material from one face of 2 in.² bar stock 16 inches long, 1030 carbon steel
    I have a 6 inch diameter 12 tooth carbide face mill Cutter On my Excel VMC with 15 hp spindle motor. It has flood cooling
    I have a lot of these parts to machine.
    Could somebody more familiar with cutting steel recommend a feed, speed and depth of cut for this job?
    Chuck
    Dec 2013
    5717
    Re: Face cutting 2 inch carbon steel bar stock
    I think hanging onto a 16 inch long bar would be a problem if you are holding it vertical. A face mill would not be my first choice to do this.
    I would lay it on it's side in a vice and use a 1 inch x 2 inch LOC roughing endmill to face it, maybe one pass, leave about 0.020 for finishing. If you need a good finish, then switch to a 1 inch finishing endmill and finish to size.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    120
    I read an interesting topic on another forum about the feeds and speeds for 1018 steel which is very similar. They seemed to suggest running it dry with an air blast was the best bet. I think Jim's setup idea sounds like the way to go. There are some nice roughing bits that should make quick work of that material. I saw some end mills at Maritool that looked like they would be just the thing for this.
    https://www.practicalmachinist.com/v...d-feed-199263/
    https://www.maritool.com/Cutting-Too...197/index.html
    Good luck!
    Jan 2011
    129
    Thanks Jim,
    I had intended Horizontal in a vice.
    I will check to see if I have a 1 inch roughing end Mill.
    As a newbie machinist trying to learn, I would like to understand why my 6 inch carbide tipped face mill would not work on this job.
    Again thanks for the suggestion of the 1 inch and Mill.
    Chuck
    Jan 2011
    129
    Thanks for the input on dry cutting, I was getting prepared to drowned it with coolant
    Dec 2013
    5717
    Quote Originally Posted by chuck767 View Post
    Chuck
    Well, part of that is just as the name implies, ''Face Mill'', not really designed for side cutting. Depending on the cutting geometry it may work, but is not really designed for what you propose.
    A roughing end mill is really the best way to remove a lot of material in a hurry. You have enough HP, so follow the endmill manufacturer recommendations for feed, speed, and coolant. All major manufactures have charts for best feeds and speeds for their products.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2011
    129
    Thanks Jim,
    Light my high school shop teacher told us, “the proper tool for a proper job”
    Dec 2013
    5717
    Thanks Jim,
    My pleasure.
    Your shop teacher was a wise man.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2017
    314
    6 inch 12 effective tooth facemill? 15hp? is this excell 50 taper
    Jim- are you describing milling it to length?
    I understand the question posed as making 2x2x16 into 2x1.75x16
    2 Vises
    would need a little more info on the facemill, which I feel is almost too large.It does have lead angle right? A 3.0 dia would be better. DOC would have to be felt out. [email protected]? watch load meter and listen.
    Dry
    500 sfm@6=318rpm
    .004iptx12=.048x318rpm=15.26ipm
    Dec 2013
    5717
    Quote Originally Posted by generaldisarray View Post
    Yes, milling to length, but maybe I misunderstood. To cut one face to 1.75 then I would do as you describe above. In that case the 6 inch face cutter would work fine.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2011
    129
    2 Vises
    Dry
    500 sfm@6=318rpm
    relative to "6 inch 12 effective tooth facemill? 15hp? is this excell 50 taper" yes, 6 inch 12 effective tooth facemill, 15hp, 40 taper
    relative to, "I understand the question posed as making 2x2x16 into 2x1.75x16" This is correct.qad yes 2 vices
    thanks for all the input..
    Chuck
    Jul 2019
    8
    Cutting carbon steel is a very elaborate process. If you are not sure, you can ask about Songshun Steel. They can give you a satisfactory answer.
    Contact :https://steelpurchase.com/steel-produced/
  1. fiber laser cutting mahcines for carbon steel 20mm
    By laserliu in forum Fiber Laser Cutting Topics
    Last Post: 05-24-2018, 04:55 AM
  2. Replies: 0
    Last Post: 01-23-2018, 03:00 AM
  3. fiber laser cutting machine cut 8mm carbon steel
    By g.weike laser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-09-2015, 04:06 AM
  4. Cutting 3/4 inch Steel
    By BOCESTorchmate in forum Torchmate
    Last Post: 10-29-2015, 07:10 PM
  5. Replies: 0
    Last Post: 08-07-2014, 02:46 AM
