586,440 active members*
4,311 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, i need a " trick " : how to align a long drill on a misaligned turret ?
    Jun 2015
    4154
    hello all the radial turret, is a bit misalinged, only on z : 0.12mm over 100mm
    please, how to align a loooong drill, without aligning the turret ? kindly
    Jun 2015
    4154
    Re: please, i need a " trick " : how to align a long drill on a misaligned turret ?
    please, what should i put between the turret and the toolholder, in order to reduce/adjust the missalignment ?
    whatever it is, maybe it should :
    ... not damage the surface of the turret or of the toolholder; even micro-surface scratches should not occur
    ... be coolant resistant
    kindly
  1. Replies: 1
    Last Post: 07-16-2023, 02:30 PM
  2. Replies: 2
    Last Post: 08-05-2018, 10:41 AM
  3. 6" long drill
    By ssphoenix in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2007, 06:59 PM
