586,075 active members*
4,164 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > please, i need a " trick " : how to align a long drill on a misaligned turret ?
Page 2 of 3 123
Results 21 to 40 of 41
  1. #21
    Mar 2015
    410
    Re: please, i need a " trick " : how to align a long drill on a misaligned turret ?
    You can use (a bunch of) aluminum foil, available in different sizes. The "kitchen" type is about 0.01 mm thick.
    Also copper will do, heat it up (red) and let it cool down, that makes it very soft. Use a press (hammer) to get it thinner to almost the right size. Then heat it up one more time, and use it to shim the turret. When it is bolted on, it will be pressed, causing it to shrink a little bit and harden. Copper seals use the same principle!
    Plastics like nylon absorb water (coolant) and get thicker. Other types like PTFE (Teflon) keep getting thinner under pressure. You could use POM that doesn't absorb water and is pretty stable under pressure.
  2. #22
    Jun 2015
    4154
    hi hfjbus, i was given a piece of aluminium from a metal can, which is 0.10thick, and had rough edges, so i did not used it
    so far i did not know about the 0.01 "kitchen" type; are these for sale ?
    about copper, thanks for the tip, but i wish to avoid the "preparation" time i mean, even if it works, i preffer to avoid it
    yes, this is what i am afraid of ... but, in that area where i put plastic, it is not exposed directly to coolant, so, if it degrades, i guess that it will not be sudden, but in time, and this may be detected by regular alignment inspection ( like once at 2-3 days eg ); that's my bet so far
    is there laminated teflon or pom, like 0.05 foils ? i don't know / kindly
  3. #23
    Apr 2016
    74
    i have not had any issue with plastic shims and coolant (i think that might depend on your coolant type. we have a a complete set of plastic shims (store bought), that we cut to our needs.
    how are you holding onto the drill?
  4. #24
    Jun 2015
    4154
    hi walker
    pls, what thickness ?
    drill > sleeve > toolholder > turret .... or what ? i am sorry, maybe i did not understood what you are asking / kindly
  5. #25
    Apr 2016
    74
    i was just curious to see how you are holding the drill.
    our shims go from .0005" to .050".
  6. #26
    Mar 2015
    410
    This is the foil you can buy in every grocery. In a specialized bakery shop, you can get thicker foils.
    You shouldn't use teflon because it is unstable under pressure.
    0.05 mm plastic foil is pretty thin and a problem to handle. I don't know in what thickness pom sheets material is sold. A quick search results in 0.1 mm PVC film and 0.125mm Mylar Film. Mylar film is easier to handle, I use it some times (0.12 mm thick)
  7. #27
    Jun 2015
    4154
    hi walker, yup, i believe i have to buy some shims ...
    ok ... i am not talking about deepholes or gundrilling, but <10 D
    i may go like this :
    ... static holder + sleeve + drill + 5mm shim ( screws are not pushing the drill shank, but the shim )
    ... static holder + sleeve + er collet + bearing nut + drill
    ... live holder + er collet + bearing nut + drill
    from all those above, 1st one has good repetability, and it is more rigid; 2nd & 3rd does not have good repetability, and are less rigid, because the collet has elastic behaviour
    so far, did you noticed an increased repetability when using one kind of setup, and less repetability with others ? kindly
    hi hfjbuis
    before you replied, i was thinking if i should ask for quote at the vendors that i work with, or if i should simply take a trip across the town bakery shop sounds perfect : please, i want some pie and some shims .... kindly
  8. #28
    Jun 2015
    4154
    hi skywalker, please :
    ... when you align, even if the tool is paralel to z axis, how do you check to be also colinear with the spindle ? and, if it is not colinear, how do you adjust ?
    ... did you noticed an increased repetability when using one kind of setup, and less repetability with others ?
    kindly
  9. #29
    Apr 2016
    74
    i put a indicator in the spindle, sweep pocket in the front and in the back.
    if i am picturing what you are doing, you can try, indicating on top and then on the front or back of the tool.
    let me know.........
  10. #30
    Jun 2015
    4154
    hi, turret and holder attached
    holder + sleeve + tool
    before the tool, i put a loong shank in there
    i move the dial indicator along the shank :
    ... dial is among Y axis, and, if shank is not paralel, i simply rotate the holder
    ... after that, i rotate the dial 90*, so now it is among X axis, and, if it is not paralel, i put some shims between holder & turret
    so far, this delivers a shank paralel to the spindle; now, i have to put it coaxial, so i use a center indicator, or a test indicator
    if something is wrong in X axis, i adjust X axis, but what if something is wrong on Y axis ?
    is it ok ? did i explained ok ? kindly
  11. #31
    Apr 2016
    74
    are you using "Y" axis for this tool?
    ours has y, but we never have used it. when okuma was here to align it, i watched, it was all in the settings, nothing mechanical.
    for drilling do you need to check y?
  12. #32
    Jun 2015
    4154
    especially for long carbide; hss is not so pretentious, but is ok to check also for hss
  13. #33
    Apr 2016
    74
    Yes, i can see this now.
    it would have to zero at it home position.
    I cannot help on the alignment for "y", sorry.
  14. #34
    Jun 2015
    4154
    an Y lathe makes it easy, but i was wondering about lathes without Y
    you do the gundriling on another machine, not on okuma ?
  15. #35
    Apr 2016
    74
    lathes without y are simple to align. nothing like doing the y on an okuma with a subspindle.
    we make gundrills here, i used to run the okuma and mazak and doosan lathes we have.
    now im programming.
  16. #36
    Jun 2015
    4154
    i am ok with okuma y lathes alignments ( low force ), geometry, encoders zeros, calibrations, etc
    so you make gundrils ? thus, you make tools ? kindly
  17. #37
    Apr 2016
    74
    i will try to remember that next time that okuma is out of whack. lol
    good luck, let know how it goes.
  18. #38
    Jun 2015
    4154
    so far i did not worked on okumas with subspindles, but only with programable tailstock ..... hmm
    about crashes, colisions, etc, i am using "my own" methods for load monitor, and i can monitorize even rapids
    this requires a nice post-processor to implement it inside all programs, using machine specific limits, thus not able to run same program on another machine ... if you wish, i can tell you more; i did not shared this inside the okuma forum, because it was developed 2 months ago, so, it is relatively new / kindly
  19. #39
    Apr 2016
    74
    we do have one okuma lb3000 with a tailstock osp300pl
  20. #40
    Jun 2015
    4154
    our okuma dealer, for whatever intervention, in some cases, sent 2 guys : one novice, and another more experimented; however, i don't agree with some of their procedures, but, overall, is ok
    even if turret geometry is within factory specs ( or even lower, because, even if factory specs may be > few hundreds, real alignment after shipment, or after service intervention, is < 3um ), this does not mean that also the tool is aligned; there are some plays that sum-up
    also, even if mechanically things are ok, there may be a shift inside the encoders origin, but this is another story
    such situations require quick reaction, and everyone likes to avoid delays
    if you wish, we can discuss a few procedures in advance / kindly
Page 2 of 3 123
  1. Replies: 1
    Last Post: 04-20-2019, 04:21 PM
  2. Replies: 2
    Last Post: 08-05-2018, 10:41 AM
  3. 6" long drill
    By ssphoenix in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2007, 06:59 PM
