586,061 active members*
4,673 visitors online*
    Feb 2012
    126
    system P-G disk format
    Does anyone happen to know the command to format a blank disk from the "request" line? "format" doesn't work.
    It won't let me save to a plain blank disk. I assume I have to format it first.
    Actually a list of commands would be extremely helpful if anyone has that knowledge anymore.
    Re: system P-G disk format
    Go to the R3 screen. Put floppy in slot 0 type DINT
    To Save:Go to RO mode, F7 key, 4 NL, 1 NL OK@file to save with a file name
    Feb 2012
    126
    Thank you drdos! I was able to successfully format the disk and back up my file
    Someone else also shared some other commands with me and I thought I should share them here in case someone else needs them in the future
    DINT 0 formats the top drive DINT 1 the lower
    FDLI L lists files on disk(usually starts at 17 or so, the first 16 being the hidden OS)
    the space-L is like DOS /p to pause the scrolling
    SAVE will put whatever currently loaded OS is running to make a new working copy
    REMOVE is used to 'copy' files
    SCRA is used to delete files- but the area will be unuseable umless the scratched file was the last one- if not, COND will free up the erased areas- takes a while
    at R3 request
    IO PRT,CN1,F14,BR9,S0 will set it up for 4800 E 7 1 procomm comms on CN1, I use that a lot to xfer ladders from IBM FLADDER into the pig
    Ive been working in imaging my system floppies with the dos freeware program imgage disk
    DAVES OLD COMPUTERS - Disk/Software Image Archive
    and have successfully created images of what I have ( PMC I, J, and L) I haven not quite yet figured out the settings to be able to successfully write those images to blank disks yet but am working on it with a vintage computer guy.
    I'd like to try and rescue the PG software from obscurity and preserve it for future users.
    Someone smart (not me) has a p-g and has "emulated the system" to run in a virtual environment.
    https://github.com/mamedev/mame/blob.../fanucspmg.cpp
    It's an interesting link with some interesting reading.
    I'm working on scanning in the PG manuals I have too.
    If anyone can or will help me with archiving the software that I'm missing (Need M, N ) but anything at all would be greatly appreciated. Please contact me directly. My PM inbox has problems The software is not available from Fanuc anymore. I don't even think they have it for themselves and if we don't archive it, it may become lost to time.
    Thanks!
    [email protected]
  1. OKUMA 700M ALERT 128 Memory Disk Format!
    By Rifataka in forum Okuma
    Last Post: 11-14-2018, 04:00 PM
  2. Disk system
    By VECKT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-19-2018, 04:02 AM
  3. Floppy Disk format type
    By Nightline in forum CNC Machining Centers
    Last Post: 12-10-2016, 08:49 PM
  4. Charmilles Robofil 310 disk format error
    By ecduplex in forum EDM Discussion General Topics
    Last Post: 12-06-2010, 09:50 AM
  5. M32 System Disk
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 01:25 PM
