586,114 active members*
3,388 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > DNM 750II Thru Spindle Coolant not purging.
    Apr 2018
    23
    Hello guys, I have one very annoying issue when using the thru spindle coolant on our DNM 750, when I finish running a tool with it turned on the coolant gets trapped behind the tool.
    In a perfect world I would never have any coolant touch the taper of my tools because this can lead to stickiness that simply doesn't happen otherwise in the pockets.
    When I tool change about 12oz. of coolant comes flying out all over the place, even if I blow air through the spindle to try to clear it out (M114)
    I especially do not like coolant getting on my probe as the stylus picks up dirt easier when it has any traces of coolant on it.
    Has anyone else experienced this and know of a fix?
    Thanks for reading!
    Jul 2005
    380
    Re: DNM 750II Thru Spindle Coolant not purging.
    A certain amount of coolant will remain after TSC usage. Even brand new machines do that.
  1. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  2. Purging way lube system
    By dfearnow in forum Haas Mills
    Last Post: 09-17-2015, 04:11 PM
  3. Through spindle coolant
    By godtar in forum Daewoo/Doosan
    Last Post: 07-19-2012, 07:11 PM
  4. Through spindle coolant
    By makingchips in forum Haas Mills
    Last Post: 02-08-2009, 02:16 AM
  5. Coolant for HF Spindle ?
    By Greolt in forum DIY CNC Router Table Machines
    Last Post: 07-03-2008, 10:59 PM
