586,070 active members*
3,417 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Recommend a mill bit please.......
    Sep 2009
    28
    Hello
    I am searching for the proper type of mill bit to most efficiently perform a profile operation on 6061 aluminum.
    Said job is as follows; Stock measures;1.5" x 3". It's a profile operation with a cutting depth of -1.5". I need to make 20(ea) of them
    My initial thoughts are to run an .5" end mill around the profile to -1.5" depth then perform the same operation using a .1875 end mill to remove the remaining material. The way I see it, load on the end mill will primarily be in the -z direction. I'm thinking 2 flute HSS. Down cut? Thanks to all who respond.
    Jerry
    Dec 2013
    5717
    Re: Recommend a mill bit please.......
    It really depends on your machine. I would use a 3 flute, 1/2'' aluminum rougher to remove as much material as possible. Use an adaptive clearing cutting strategy, if your machine will take it, DOC should be about 3/4'' for the roughing passes.
    Do not use a down cut bit, you need to clear the chips. Flood coolant would be the best, but a good spray mist would work.
    Most of the load on the tool is radial, not axial.
    Pre-drill where the 0.093 radii will be to reduce the cutting load on the 3/16 endmill in the corners. If possible, make the radii at least 0.100 to reduce the contact area of the 3/16 endmill as it cuts into the corners. 1.5'' is a large DOC for a 3/16 endmill, I would use an endmill with a relieved shank and about 1/4 inch of cutting length, then spiral down for the finish passes.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2009
    28
    Hi Jim
    Thanks for the advice!
    Jerry
  1. Which would you recommend for cnc mill?
    By Gamble in forum Benchtop Machines
    Last Post: 02-08-2017, 08:07 PM
  2. recommend me cnc mill for machining moulds
    By pewpawn in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2016, 07:46 PM
  3. Replies: 4
    Last Post: 04-21-2015, 03:47 PM
  4. Would you recommend ER-16 spindle for sherline mill
    By tgab101 in forum Benchtop Machines
    Last Post: 01-07-2013, 07:52 PM
  5. How big of a mill would you recommend?
    By theMightyCasper in forum Benchtop Machines
    Last Post: 12-04-2009, 05:11 PM
