586,414 active members*
3,312 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > EZCAD2 for Windows 10 OS fiber laser engraving machine
Page 2 of 3 123
Results 21 to 40 of 44
  1. #21
    Aug 2020
    Re: EZCAD2 for Windows 10 OS fiber laser engraving machine
    HOLA SERIAS TAN AMABLE NECESITO EL SOFTWARE DE EZCAD2 PARA MI PC WIN 10 DE 64 BIT INSTALÈ UNO PERO ES PARA EL WIN8
  2. #22
    Aug 2020
    software EZCAD2 PARA WIN 10 64 BITS .- Instale este pero solo DEMO PRUEBA . SALE Q ES VESION WIN 8 Y NO PUEDO INSTALARLO PORQUE TAMPOCO ME APARECE OTHER DEVICES. ESPERO SU RESPUESTA . SALUDOS !
  3. #23
    Sep 2020
    6
    Quote Originally Posted by Andun View Post
    I have Ezcad2.9.9 and It was working fine with windows 7. and Install Windows 10 64bit version and when software opening it's saying "Can not find dongle.demo state".
    when i try to engrave it's saying "Current LMC Board is not for fiber Laser"
    And parameter setting F3 hardware info showing "invalid board"
    but i tried to work with windows 7 again (old hard drive) it was working file.I think problem with windows 10 64bit. installation issue.
    Does anyone have Ezcad2.9.9 software and drivers for windows 10 64bit?
    or any other solution for it?
    Thank you
    from Sri Lanka
    Did you sort this out. I’m having exactly the same issue. Just installed a brand new control board and the problem is still the same.
  4. #24
    Sep 2020
    6
    Quote Originally Posted by maciej_rz View Post
    hello
    yes, i can and i did it.
    i updated driver as shown on YT movie but already have te same driver.
    Unfortunately software still says about missing dong
    Did you fix your issue, I'm having exactly the same problem.
  5. #25
    Aug 2020
    20
    Official EZCAD homepage https://www.chineselaser.com/
  6. #26
    Aug 2020
    20
    For any issue of your <a href="https://www.chineselaser.com/3d-laser-marking-software-product/" target="_blank">laser marking software EZCAD</a>, you can try to contact the developer, JCZ.
  7. #27
    Unhappy Re: EZCAD2 for Windows 10 OS fiber laser engraving machine
    Quote Originally Posted by LILYHERE View Post
    Hola Lily
    Tengo el mismo problema pudiste resolverlo de alguna forma????
    llevo 1 semana tratando de solucionar esto y me estoy volviendo loco.
  8. #28
    Oct 2020
    Quote Originally Posted by Airskinz View Post
    The USB driver needs to be updated while the laser is connected and in the full on state, as the control card acts as the "dongle". If you are receiving a missing dongle message, it means that the computer is not seeing the laser. Check that your laser state is on and try again.
  9. #29
    Dec 2020
    He, was d6wn36ad driver from your given link but i see it's not working. i am using windows 10. Please need your help.
  10. #30
    May 2018
    35
    Heelo Iaboni,what's the version of your software?How's your control board looks like?Could you send a picture?
  11. #31
    Can someone send me the link to download ezcad2v14 plz. Thanks in advance
  12. #32
    May 2018
    35
  13. #33
    Feb 2021
    Quote Originally Posted by Kags View Post
    I purchased a fiber laser engraving machine from china a few months ago. EZCAD 2 kept crashing on the Windows 7 computer they sent me. Finally im guessing some of the components in the computer they sent with the machine were less than adequate and the computer took a turn. I have since purchased a laptop for use on the machine only. I was hoping someone could point me in the right direction getting software to work on windows 10 OS so that i have a reliable computer to work off of. Very new to fiber laser but the possibilities are endless and am willing to handle the learning curve. I just need a little help here and there. Thanks in advance!
    Boa noite
    A pen onde vinha o ezcad2 não é reconhecida.
    Formatei o meu pc e fiquei sem o software ezcad2.
    Cada máquina laser fibra 20w racyus tem o seu software ou o ezcad2 dá para qualquer maquina laser fibra 20w racyus.
    Pedia uma ajuda a ver se consigo resolver esta situação dado que a máquina assim não funciona.
    Obrigado
  14. #34
    Apr 2021
    Quote Originally Posted by EZCAD View Post
    I have three machines and on one I keep getting errors on the lmc driver
  15. #35
    please, send me driver and sofware of control board laser mark V1 for win xp. thank you very much
  16. #36
    Quote Originally Posted by Opticlaser View Post
    Here is the software.
    thnks...........
  17. #37
    Smile Re: EZCAD2 for Windows 10 OS fiber laser engraving machine
    hi we are trying to use ezcad2.14.11 and it wont let us use the sent software we have win 10 can you help us??
    thank you
  18. #38
    May 2015
    Quote Originally Posted by ABCOSTA View Post
    Boa noite
    Obrigado
    bom dia Já resolveu o seu problema? também comprei a semana passada uma Fiber Laser da china e ainda não consegui que funcionasse.
    Filipe-Portugal
  19. #39
    May 2015
    o red pointer funciona, se fizermos um rectangulo ele apresenta-o na base mas depois não marca nada. the red pointer works, if we made a square he shows it in the worktable but then not marking nothing..
  20. #40
    Jan 2019
    Dear friends,
    I have got the same problem:
    Windows 10
    Ezcad 2.14.11
    FBLI-B-LV4A
    The drivers are in X64AMD_LmcV2u, which containes 4 files (Lmcv2u, Lmcv2u.sys, lmcv2uX64 and WdfCoInstaller01009.dll)
    I find this youtube video https://www.youtube.com/watch?v=n5YGY0wOgI4&t=3s, which has windows 10, Ezcad 2.14.19 and uses the driver pacvkage JCZDriverAllInOne. This has 6 files in it (JCLMC.Lmc.sys,lmcDrv, LMCUSB.sys, Lmcv2u.sys and WdfCoInstaller01009.dll)
    I have these drivers but not Ezcad 2.14.19.
    Is this the fix?
    I tried updating the drivers with the board connected as indicated above but with no results..
    Does somebody has a 2.14.19 download link?
    Best regards,
    Paul
Page 2 of 3 123
  1. Morn Fiber laser/ezcad2 stuck in demo mode
    By panaceabeachbum in forum Fiber Laser Cutting Topics
    Last Post: 03-02-2022, 08:08 PM
