586,455 active members*
3,329 visitors online*
    Apr 2019
    Question CNC newbie: Tool Offset question.
    Good Morning!
    I have been writing simple CNC programs on a Fagor 8025T for a lathe. I'm getting good product but I have a gap in my education: I'm not sure I understand Tool Offsets.
    My understanding is: I touch each tool off on a sample part in X and Z using the procedure outlined in the manual. (Done)
    In watching videos on Youtube, It seems as if I need to touch a master tool to the face of each example part for each program so that the program knows where Part-Zero is. (I haven't found this procedure yet)
    The CNC now knows where the tip of each tool is in relation to Part-Zero for each program. The idea is I don't have to re-touch ALL tools for each program. Correct?
    If my guess IS right, where to I load this Part-Zero in each program?
    Regards to you all!
    Glenn
    Apr 2016
    74
    Re: CNC newbie: Tool Offset question.
    i take it your machine has no tool arm (touchsetter) to set tools with?
    the video showing no.1 tool as your main tool, then all other tools are the difference in Z and X from tool#2,3,4 ect are to the no.1 tool.
    The idea being once that is done, you only have to touch tool #1 to the face of the part. all others know where they are from tool #1.
    I hope this makes sense. you do not have to have a "master tool". i ran a mazak for years and never did.
    Aug 2009
    1573
    Where is Machine Home Postion at?
    Any Pictures of your Machine Setup?
    Is this your Control...want Ver # http://www.fagorautomation.com/downl...8025t_user.pdf
    One note to using TO's on Lathe's is try to use negitive(-) numbers XZ for Offsets. just for safety, because if someone changes a TO and forgets the minus sign......no crash..just hits Limit Switch
  1. Tool length offset question
    By nelZ in forum Haas Mills
    Last Post: 12-25-2016, 10:43 PM
  2. Hi all, Tool diameter offset question.
    By chad123 in forum Haas Mills
    Last Post: 03-14-2008, 08:02 AM
  3. tool offset question
    By WarrenW in forum SheetCam
    Last Post: 04-29-2006, 07:43 AM
  4. question about Yasnac tool offset in the Z
    By DDuley in forum DNC Problems and Solutions
    Last Post: 02-19-2006, 02:23 AM
  5. G43 Tool Offset question
    By sbrunton in forum LinuxCNC (formerly EMC2)
    Last Post: 07-21-2005, 04:53 AM
