586,067 active members*
5,116 visitors online*
    Gerry 2010 auto zero
    I have searched all over the internet for the auto tool zero.Do I have to use two length sensors?I have only one and I would like to put in a fixed position.
    I work with Vectric Aspire and I use mostly 2-3 tools.
    I want to measure each tool at the fixed position,is this possible using only one touch plate?
    Measure the first tool,insert the gcode,begin code,return for the second tool,change tool,go to fixed position to measure tool,continue job etc?
    I find very useful the interface and I really love the simplicity of Gerry 2010.
    Re: Gerry 2010 auto zero
    Copied from my reply to your email.
    Yes, you can only use one fixed plate. There are two different ways to do it.
    1) Mount the plate to the spoilboard or table, and set Z zero to be the bottom of your stock in Aspire.
    2) If you zero to the top, then use the Material Offset option in the 2010 Screenset to specify where Z zero is relative to the bottom of the fixed plate.
    With either method, you'll need to jog over to the fixed plate, and run the Initial Auto Zero, which sets Z zero, and stores the fixed plate location.
    The after tool changes, the tool will automatically be measured to the fixed plate.
    Big thanks to Gerry,he knows how to support his work!
    Feb 2009
    6028
    Agree. I have the dual zero plate on mine, one in the spoilboard and one movable. Makes long runs much easier.
  1. 2010 Screenset and PMDX-126 Auto tool setting Setup
    By lancut in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-21-2017, 02:41 AM
  2. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  3. Gerry dethroned as most prolific poster???
    By louieatienza in forum Uncategorised WoodWorking Machines
    Last Post: 12-25-2013, 05:54 PM
  4. Shout out to Gerry!
    By Mountaincraft in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 06:08 AM
  5. reply to gerry
    By cook in forum DNC Problems and Solutions
    Last Post: 12-22-2007, 08:00 PM
