586,113 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF-45 Clone Mill > RF-45 clone (grizzly) automatic tool changer build
Results 1 to 7 of 7
    Mar 2013
    8
    Hello everyone!
    I decided to tackle building a 12 tool ATC that uses the tormach tts tools. I started the build last week and want to share it here. I also got lots of video I'll upload to you tube when I have time to edit it.
    So far I started out making the tools holders. The holders are split into to pieces, a top HDPE plastic tool retainer, and a bottom steel holder that slips into the tool collar. The tool holders turned out well so I mounted them to the carousel wheel.
    Holding the carousel is a mild steel axle with a double row angular contact bearing. Its a 5202 with a 15mm center and 35mm od.
    I First tried to use one of the bigger timing belt pulleys I had from another project but it ended up interfering with the head of the mill. So it now has a 1:1 pulley about 2" diameter. There is a 425 oz/in stepper to drive the carousel.
    I used 16mm linear bearings and a 12in stroke 1.5" air cylinder for moving the carousel in and out.
    For testing I am running a parallel port breakout board, however my friend is helping to design a modbus controller which will talk to Mach 3. that way is it just is a simple M6 macro in Mach to control the tool change. We hope to have changer working this weekend with all the sensors.
    we will have sensors on tool 1 position, cylinder in and out, power draw bar release and engage, and main air pressure in. that way if there is a problem somewhere during a tool change it will e stop the machine.
    If you guys have any input on the build or questions I would love the input!
    Nov 2005
    222
    Re: RF-45 clone (grizzly) automatic tool changer build
    Cool project. Looking forward to the videos.
    John
    Jan 2014
    126
    Looking Good!
    Mar 2013
    8
    Here is the first video. I will shoot more this weekend while we are working on the controller and hopefully making to work.
    Mar 2013
    8
    Hello guys, here is a quick progress update on the build. Enjoy!
    Mar 2013
    8
    I finally got the ATC working! My buddy Larry was going to make a custom board to work with Mach 3, but due to his limited time and Mach 3 being a pain to work with I ended up finding Masso. When I started looking into a Masso controller I found they had support for ATC's. After installing the Masso and working out some bugs I was able to get the ATC working. Here is a video I posted on the progress.
    Dec 2007
    468
    That is totally awesome!!!
  1. Yes. Another RF-45 clone build (Grizzly G0762)
    By 109jb in forum RF-45 Clone Mill
    Last Post: 12-24-2018, 07:46 AM
  2. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  3. Automatic Tool Changer
    By Rockwall in forum Tormach Personal CNC Mill
    Last Post: 04-21-2008, 11:34 PM
  4. Automatic tool changer
    By bunalmis in forum Mechanical Calculations/Engineering Design
    Last Post: 02-04-2006, 10:57 PM
