586,501 active members*
2,556 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > GME's New 80/20 CNC Build - My Design
Page 21 of 21 11192021
Results 401 to 406 of 406
  1. #401
    Apr 2016
    841
    Re: GME's New 80/20 CNC Build - My Design
    Quote Originally Posted by Ntl View Post
    Hey Gary are you going to post pictures of the finished machine? I wanted to see how all your hard work turned out. How did it wind up budget wise,were you close to your target?
    Good evening, Dan.
    Sure, I can post some pictures when I'm finally done.
    Right now, I'm rethinking my support structure. My first machine had two torsion box cabinets as the support base. Each cabinet was 60" long x 24" deep. there was a torsion box at each end and in the middle. I then added a torsion box top that the CNC set on. I used hockey puck adjustable feet that screwed into coupling nuts epoxied into the torsion boxes. So, I had 5 feet per cabinet. Very rigid; no vibration issues. Solid as a rock.
    My plan was to add some aluminum gussets to the legs and support braces to increase rigidity. I even have the gussets rough cut and ready for final cutting on the CNC. I was about ready to cut them, when the idea of making new cabinets for this machine occurred to me. I repurposed my old ones, although I could resurrect them, if they are tall enough. I need to measure them. Also, I don't want a total of 4' of depth. I don't need it, and I prefer to have my electronics underneath the spoilboard, rather than on the side, where they take up too much space. I want a final bed height of of something around 38.5" to give me a final height of around 40" for joinery purposes. I really wish I could have way more height for joinery, but I'd need a ladder to use the machine.
    I'm still chewing on which way to go, although I know cabinets would provide the more solid substructure. I suppose I could weld a frame, but I want something perfectly flat. I couldn't get that by welding, but can get there with torsion boxes.
    Although I have far from unlimited resources (I'm retired after all) I really didn't have a rigid budget. The greatest costs were in purchasing the aluminum and hardware from 80/20, so I had those costs up front. On top of that, I replaced some cabling, and bought some aluminum plate and angle. I also bought Hiwin linear rail components and the Avid CNC Z axis. The extra costs probably totaled around $2,500 or so. I'm at about $5,500, all in, excluding motors, electronics, spindle, etc, which I already had and were functioning properly. A few hundred more than the Avid Pro 4x4 kit + leg kit, but my machine is nearly twice as heavy (the extrusions are twice the size of Avid's, except for the gantry beam) and I have much higher quality (and more expensive) linear rails. Cost wise, it worked out at about what I expected. No major surprises.
    Gary
  2. #402
    Aug 2018
    621
    Thanks Gary and from what I can see it looks really nice. I cringed when I sat down and totaled everything up, there was so much in odds and ends that I didn't factor in orginally. I finally got a proper dust collector which is so nice compared to the shop vac. It's amazing how much quieter the 2hp dust collector is than the little shop vac I was using.
    Looking forward to the finished pictures and a video. Great job with the machine Gary
  3. #403
    Gerry, (ger21), if you happen across this post, feel free to share it wherever you want in conjunction with Joint Cam.
    I posted a link to your post on the JointCAM forum. Thanks for sharing.
  4. #404
    Feb 2020
    4
    Just for reference - I am reading through forum posts to get up to speed on AVID's Pro series kits. In talking to AVID, they said their leg kit uses an ultra lite 80/20 section and their table (rails and cross members) used the heavier section.
  5. #405
    Aug 2005
    205
    I bought a Pro series kit with standard base a couple of years ago. Avid is very willing to modify to suit customer needs. I believe base parts can be easily up graded to 40 series at extra cost.
    These machines are fairly light, if you're considering doing commercial work. I've braced mine to my poured concrete foundation walls and all flex is gone. I initially was running feeds of 200 IPM with 600 IPM rapids, no problems. I've since slowed things down a bit for safety.
  6. #406
    Mar 2010
    621
    Quote Originally Posted by GME View Post
    Here is my joinery jig designed to cut standard joinery off the front edge of my CNC. Although it's my design, I borrowed heavily from the Leigh D4 series commercial jigs. In fact, I did more than borrow from the jig design, I also borrowed the clamps and springs from the D4 jig I've owned for many years. The clamps are the black ones at the top and front corners.
    The base for the jig composed of 2 pieces of 80/20 smooth extrusion, 1.5" x 4.5" x 42". If you look closely at the front, you will see 5 holes drilled in the top slot. The holes are for access to button head cap screws used to attach the two extrusions together. When connected, I have 4.5" of height at the front and 6" of depth across the top.
    The stock is clamped using a 1.25 x 1.25 x 42" x .125" wall square aluminum tube. 5/16" studs cut from threaded rod are attached to 80/20 fasteners captured in the extrusion slots and held rigid with a 5/16" nut.
    You can also see 3 holes in the aluminum tube, 2 with studs and the one in the center open. The studs are readily removable. They allow me to use any width of stock and be able to tightly hold it in place. I have some 5/16" knobs on order, which I'll use to tighten down the tube.
    This is a closer shot to the right side. You can see vertical and horizontal pieces of 1" x 1/8" thick aluminum bar stock used as a material stop. The same arrangement is on the left side. Cut the vertical side a little long, so the top extended about 1/8" above the horizontal face of the extrusions. I used a square to align the vertical face, and the 1/8" projection gave me a hard surface to use to align the horizontal stop perpendicular to the vertical.
    This is a closeup shot of the right side from a different angle. You can see the stops and how they attach. You can see the compressed screen behind the vertical tubing clamp
    This photos show the side of the aluminum tube that contacts the stock. The red material is 220 grit glued on sandpaper. I learned that stock can slip on the Leigh jig and sandpaper cured the problem.
    You will also note that the large holes in the tubing. I cut them on my mill. They are large enough to allow the springs to easily go inside the tube, and are large enough to go over the nuts holding the studs captive. That means I can clamp all the way down to the surface of the stops, which allow me to use stock that is thicker than the 1/8" thickness of the stops. I doubt I'll be cutting much on stock in the 1/8"-1/4" range, but I will have the capacity.
    There is big difference between the Leigh jig and mine. The Leigh jig uses fingers to position stock vertically and horizontally, and has a large void in the body to allow the cutters to enter the stock without contacting the jig body or parts. That cannot be easily replicated using 80/20. My solution follows:
    My solution is a 1" thick piece of acrylic with tapped holes and a 1/4" thick piece of aluminum bar stock screwed to it.
    Here is another shot of it in place. I made it large enough to use the clamp to hold it in place with the top bar clamp. I just clamp the stop in place slide the stock up until it makes contact. This stop will work with 3/4" thick and thinner stock. I'll need to make a different stop of thicker stock. I probably won't be making many dovetails in thicker stock, but I will definitely be making tenons in thicker material.
    Finally, there is the question of how to attach the jig to my spoilboard so I have a rigid connection that won't interfere with stock mounted horizontally, as when making single pass half-blind dovetails. My solution was 3 pieces of 1.5" x 1.5" aluminum angle. As is the usual case, the two faces of the aluminum angle were not perpendicular. They were close, but no cigar. I use my mill to square the faces, and drill the holes. Using 80/20 fasteners, I was able to slide the angle until it aligned with my t-slots and used 1/4" studs and slide-in t-nuts to hold the jig in place. I ended up with a rock solid connection.
    Oh, one other thing. I believe I mentioned it in a previous post, but I ran a cutter across the front edge of the spoilboard to establish a straight edge perpendicular to the Y-axis. So, I just but the jig up against the front edge, tighten it down, and I'm good to go. No other alignment necessary.
    I am happy to answer questions. No secrets here.
    Gerry, (ger21), if you happen across this post, feel free to share it wherever you want in conjunction with Joint Cam. If you have suggestions where I might post this elsewhere, I'm open to suggestions.
    Gary
    I like to see your jig in action... shoot some video of it next time your running some material through it. I've been thinking of a design and how to make one for a bit now..
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
  1. First Design Build (doing it on the cheap!)
    By Louis_Cannell in forum DIY CNC Router Table Machines
    Last Post: 05-05-2016, 12:34 AM
  2. Design and Build
    By Eddymeister in forum DIY CNC Router Table Machines
    Last Post: 08-18-2011, 09:33 AM
  3. new to DIY CNC. want to build. have question about best design.
    By mkyle in forum DIY CNC Router Table Machines
    Last Post: 02-17-2011, 09:02 AM
  4. Can I design and build a CNC Router!?
    By morgandhunter in forum DIY CNC Router Table Machines
    Last Post: 10-13-2009, 08:49 PM
  5. What CNC design did you build first?
    By soundmotor in forum DIY CNC Router Table Machines
    Last Post: 04-29-2006, 03:05 AM
