586,052 active members*
4,414 visitors online*
Thread: HAAS P-Cool
Results 1 to 8 of 8
    Jan 2014
    32
    HAAS P-Cool
    I can hear constant air coming from my P-Cool, I took the cover off and along with the wiring there's a small 1/8" tube blowing air non stop.
    What is the purpose of this?
    Can I plug it? I know its very small, but overnight it drains my air compressor and I feel like my air compressor turns on more often than it needs too.
    Apr 2019
    13
    Re: HAAS P-Cool
    hi , by p-cool I assume it's the programmable coolant nozzle?
    I know air flows through the spindle bearings for a long time to oil the bearings and prevent coolant ingress into the bearings
    are you sure it's through the programmable coolant?
    Jan 2014
    32
    Re: HAAS P-Cool
    Positive its coming from the P-Cool (programmable coolant) as in my initial post I stated "I took the cover off and along with the wiring there's a small 1/8" tube blowing air non stop."
    May 2016
    526
    Re: HAAS P-Cool
    Very strange even just checked my spare one and it doesn't have an air fitting I thought was only power cable and coolant feed to them
    Can you locate the actuator that switches the air on and off ?
    Nov 2012
    145
    Re: HAAS P-Cool
    No air on mine
    Jan 2014
    32
    Re: HAAS P-Cool
    Took the cover off today and took a picture, red arrow pointing at it......it never stops blowing air.....haven't had a chance to route the tube to where it comes from.
    Jun 2003
    1365
    Re: HAAS P-Cool
    Someone probably added it to maintain positive pressure to keep coolant out.
    Nov 2012
    145
    Re: HAAS P-Cool
    So where is the other end of the tube located? Could you have a leak somewhere else but notice it on this end.
  1. Haas Mini Mill P-Cool problems
    By amphib in forum Haas Mills
    Last Post: 08-09-2016, 02:51 AM
  2. Do you think this will be cool enough?
    By spooner777 in forum CNC Machine Related Electronics
    Last Post: 07-28-2014, 05:46 AM
  3. Replies: 0
    Last Post: 01-21-2014, 06:07 AM
  4. Replies: 0
    Last Post: 01-14-2014, 05:50 AM
  5. want to see something very cool
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2005, 01:22 PM
