586,036 active members*
3,789 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > wiring inside the electronics cabinet
Results 1 to 12 of 12
    Mar 2011
    357
    I have shielded cable(limits and motors) coming to 5 pin aircraft plugs on the side of my cabinet. Do need to run shielded cable inside the cabinet from the plugs to where ever the cables are going?
    15362
    Re: wiring inside the electronics cabinet
    Quote Originally Posted by tkms002 View Post
    In some cases it does not need it if you use twisted pairs, inside the cabinet, it is always better not to use connectors and run the cable through cable restraints ( Glands ) and direct wire inside to drives Etc
    Mactec54
    Mar 2011
    357
    I wanted to be able to disconnect the cabinet in case I had to do something with it.
    What do you recommend?
    24221
    If using military style (MS) connectors, or similar, I generally use one pin for the shield, if needed, and take the enclosure side connector shield pin to the ground connector or star point, which ever is closer.
    Al.
    Albert E.
    Mar 2011
    357
    Al.
    I have the shield connected to the metal connector body and that is connected to the chassis which is grounded to a ground bus bar.
    Not using a pin but rather the entire connector body.
    24221
    That's one way, should be sufficient.
    Al.
    Albert E.
    Sep 2005
    1740
    Going with correctly installed connectors is the only right way to build a panel. Grommets are old school. Organize wiring inside the cabinet keeping the low voltage and signal cables away from the power wiring. Power wiring always came in at the bottom in conduit and left the same way.
    ericks Guest
    Good quality connectors that are rated for the correct current and voltage requirements are important. Also any cables you use must also be rated accordingly
    15362
    If your Plugs are good quality they will be fine and the way you have done them with the shield termination is the correct way to do it, from the plugs inside just use twisted pairs where ever you can
    Mactec54
    Mar 2011
    357
    thank you all
    Mar 2011
    357
    ok for the limit switch wiring inside the cabinet I just ran a length of cat6 cable using a pair for each limit switch axis from the cabinet mounted connector to the arduino pins.
    Hope that makes sense.
    Now, for the motor wiring I cant use cat6 cable as it is to small so can I just twist up some 18ga wire for each motor? 5 amps so 18ga should be enough.
    15362
    You could try and use the 18ga as twisted pairs, cat6 is fine for limits just Ground the shields at the source end for these wires
    Mactec54
  1. CNC electrical cabinet wiring organization
    By roflwaffle in forum Maintenance DIY Discussion
    Last Post: 09-23-2015, 06:26 PM
  2. Replies: 2
    Last Post: 05-17-2014, 01:19 AM
  3. Your prefernce for Cabinet Wiring
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 03-16-2012, 07:07 PM
  4. Wiring 220V and 110V inside of CNC Electronics Cabinet
    By MRM RCModels in forum CNC Machine Related Electronics
    Last Post: 01-16-2010, 01:00 AM
  5. Electronics cabinet
    By mcArch in forum CNC Machine Related Electronics
    Last Post: 08-05-2008, 04:02 AM
