586,463 active members*
3,338 visitors online*
    Apr 2015
    72
    UCCNC and Vistacnc P4-s
    I am in the process of switching from Mach3 to UCCNC. I first had a setback trying to get my SuperPID to work properly but now have that pretty well set. I also purchased the newer XHC pendant but found that there was no driver or plugin to use it in UCCNC so I returned it and decided to get one that was fully support. Even though it was more than what I had planned to spend I went for the VistaCNC P4-s pendant. But I still have a problem. I cannot get the configuration page to open to set options.
    I copied the plugin to the plugin directory
    Enabled it
    Restarted UCCNC and go to configuration page. When I click on the Configuration button, nothing happens. No new window or pop up window appears. The pendant does work for some things. I can jog, although step jogging is a bit jerky. Spindle start and start work and I can adjust spindle speed and feed. But with out getting into the configuration I can't fine tune or set screens or macros.
    Any ideas why the configuration page wont open? I emailed VistaCNC but haven't heard back. I also posted in the UCCNC forum.
    Windows 10
    UCCNC 1.2049
    UC300ETH
    VistaCNC p4-s
    Sam
    Apr 2015
    72
    Re: UCCNC and Vistacnc P4-s
    Well I got an email from Lee at VistaCNC. The current plugin does not support the configuration window yet. Next version is supposed to do this.
  1. Mach4 and vistaCNC PA3 pendant
    By Dean448 in forum Mach 4
    Last Post: 07-01-2018, 10:14 PM
  2. Issue with UCCNC HW and VistaCNC P4-SE pendant
    By ronsand in forum UCCNC Control Software
    Last Post: 02-12-2018, 09:08 AM
  3. Waiting for VistaCNC plugin for UCCNC
    By iflyinverted in forum UCCNC Control Software
    Last Post: 05-25-2016, 04:20 AM
  4. VistaCNC Pendent Help
    By eman5oh in forum Mach Software (ArtSoft software)
    Last Post: 10-27-2014, 11:53 PM
  5. VistaCNC iMach-Pro Pendant
    By SCzEngrgGroup in forum CNC Machine Related Electronics
    Last Post: 10-14-2014, 01:14 PM
