586,521 active members*
3,580 visitors online*
    Y-axis cutting quality
    Hi, I have problem with 250W CO2 metal cutter. If y-axis moving down the
    cutting line is fine. but moving in oposite
    direction the cutting line is very poor.Have there eny common
    reasion?
    Aug 2018
    28
    Re: Y-axis cutting quality
    Did you check the calibration of the mirrors? between the mirrors 2 and 3 is the calibration of the X axis. I think the problem may be there. Logically I am talking about an optical system with 3 mirrors.
    Regards!
    we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
  1. Cutting Quality 3/4 MDF
    By Wisker in forum Uncategorised WoodWorking Machines
    Last Post: 05-08-2017, 12:46 PM
  2. Terrible Cutting Quality
    By jlowe1224 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2015, 09:14 AM
  3. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum Other Machine Topics
    Last Post: 05-09-2014, 08:41 AM
  4. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum News Announcements
    Last Post: 04-18-2014, 02:17 AM
