586,069 active members*
3,877 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Need help! NEMA 34 Power supply (transformers)
    Jan 2019
    Hello Guys,
    I'm new here, and i would like to ask something which i don't understand . So i plan to build one machine and use 4Axis NEMA 34 stepper motors which coming from the seller with 1200W 60VAC ring transformer for all four, Question is: can I supply individually each steeper with 200VA control transformer PRIMARY 230VAC (0.86A) SECONDARY 24VAC (8.33A)
    Link to the ebay product I'm looking to purchase: https://www.ebay.com/itm/4Axis-Nema3...N0Aq0a4TtSSpjg
    Thank you in advance to all for your help and time consuming for the answer.
    Dec 2013
    5717
    Re: Need help! NEMA 34 Power supply (transformers)
    The short answer is: NO
    The system you link to would not work well supplying 24V to the drives. You always want to supply the drives as close to the maximum rated voltage as possible.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2019
    Thank you Jim!
  1. power supply wattage for 4 nema 23
    By quenouille in forum CNC Machine Related Electronics
    Last Post: 05-01-2017, 05:02 PM
  2. Nema motor Power supply
    By aquaveg in forum Open Source CNC Machine Designs
    Last Post: 01-23-2012, 12:15 PM
  3. Using 2 Transformers to build Power Supply
    By millman52 in forum CNC Machine Related Electronics
    Last Post: 01-20-2008, 10:04 PM
  4. Power supply and Nema 17
    By woodturn in forum Stepper Motors / Drives
    Last Post: 02-13-2007, 05:11 PM
