586,911 active members*
3,805 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Mach3 and 6040 - something is making engravings larger
    Mar 2019
    26
    Hey all,
    Finally got the 6040 working, bit of a mishmash really, a blue box Frame and a PRT-E1500W controller with a Huangyung (spelling) VFD and everything appears to work as it should except anything I try to engrave or cut out, appears to end up atleast 10 - 15% larger e.g. Engraved a brass plaque then cut out it out (oval shape) now when I designed in Aspire it was 12cm total width - the finished job was 14cm wide. I put that down to a cockup on my part, except last night when I went to cut out some timber ends to build a modular synth last night and I had to E-Stop the machine as it was going to do the same thing as in the height was going from 480 to 520, a guess - hit the E-Stop as it was heading for a clamp.
    Anyone have any ideas where to look as to what would be causing it to enlarge jobs, I've never come across this?
    Cheers
    Taff
    Mar 2016
    45
    Re: Mach3 and 6040 - something is making engravings larger
    Quote Originally Posted by TaffyCarl View Post
    Hey all,
    Cheers
    Taff
    Sounds like maybe your steps settings may be off. When you tell it to go 100mm what does the accual move measure?
    Sent from my Nexus 6 using Tapatalk
    Mar 2019
    26
    Quote Originally Posted by carl1961 View Post
    Nailed it Carl, manual settings say 400 dropped it to 320 and bingo 100mm now equals 100mm
    Cheers
    Carl
  1. Making the Chinese 6040 larger ?
    By m0ng00se in forum Mechanical Calculations/Engineering Design
    Last Post: 04-10-2017, 11:02 PM
  2. Making Bowls on a Carving CNC 6040
    By RussellK in forum Chinese Machines
    Last Post: 11-10-2014, 12:10 PM
  3. Machine jogs larger distance than keyboard input - Mach3 Gecko 203v
    By FoxCNC1 in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2014, 05:27 AM
