586,110 active members*
3,354 visitors online*
    Sep 2005
    274
    2003 vm25 7 control
    How come when I use cutter comp this machine comes in at a angle even when I program it to come in 90 deg (perp) ? parameter? Thanks
    Mar 2017
    63
    Re: 2003 vm25 7 control
    You have to program a lead in. Perpendicular or at an angle or maybe even arc. You cant come in straight. It compensates in the first move.
    Sent from my SM-N960U using Tapatalk
    Sep 2005
    274
    Thanks for the reply, yes I do have a lead in, I program it to come in at a perpendicular line to pick up the comp and the control moves in X and Y
    I did see a parameter in my fast cam2 that might fix this, I also seen some other posts asking the same thing, I will see if the parameter is the same in the machine, I did not see it in the programming manual.
    Sep 2005
    274
    Yes the parameter 90 degree cutter comp works
  1. Warthog 2003 4x8
    By skyiron in forum Commercial CNC Wood Routers
    Last Post: 07-21-2016, 02:32 AM
  2. 2003: Arm 60D m/c lock?
    By markamara in forum Fanuc
    Last Post: 02-08-2012, 11:17 AM
  3. Need help importing SW 2003 into BCC v.24
    By jjayharrison in forum BobCad-Cam
    Last Post: 06-21-2011, 01:07 PM
  4. g2002/2003 ?
    By broncosis in forum Gecko Drives
    Last Post: 10-26-2004, 12:49 PM
  5. Autocad 2003
    By johnm in forum Autodesk
    Last Post: 06-06-2003, 05:35 PM
