586,080 active members*
3,468 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jun 2014
    12
    Wiring problem with servo drive
    Hi ,
    my servo drive won't power up
    The servo motor are short circuit
    Can anybody help me with this wiring.i follow dmm wiring but still dont power up.please help.
    Thank you.
    Sent from my SM-N950F using Tapatalk
    Dec 2013
    5717
    Re: Wiring problem with servo drive
    Can you post a picture of your wiring?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2014
    12
    Hi freind,
    The servo motor been short circuit.
    That puzzle me.
    I think i follow the wiring diagram exactly.
    I need an advice.
    Thank you
    15362
    Quote Originally Posted by bustamam View Post
    Hi freind,
    That puzzle me.
    I need an advice.
    Thank you
    You have not Main Power supply Ground or Motor Ground connected you also don't have the Logic power filter or protection in place
    Check the servo motor connections A B C and pins for the servo motor wire connections at the servo drive if these are not correct then you will get a short and can cause damage
    What is your max Voltage supply ???
    Mactec54
    Dec 2013
    5717
    I don't see any obvious wiring errors. With the power on, are you getting 230V across R and S, and across L1 and L2? Do you have 230V to your breaker?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2014
    12
    Hi jim,
    I have to check back the voltage .
    Aug 2009
    1573
    Hi jim,
    ...that Post was almost one year ago.... you must be a busy man. Keep us posted if, anything gets fixed,
    DJ
    Jun 2014
    12
    DJ
    Thank you dj, im stuck here with that machine cause of convid 19, down here in msia we strickly have to stay home.
    Hope everyone safe.
    Jun 2014
    12
    Hi mactec54,
    Thank you for your prompt reply.
    My maximun voltage is 240v.
    I will try your advice.
    I really apreciate your help.
    Thank you
    15362
    Hi mactec54,
    Thank you
    The Power filter and protection for the logic wiring won't change anything, it's just a requirement once you do the install
    Mactec54
    Jun 2014
    12
    Hi mactec,
    Very good morning to you,
    As usually i need you advice on my cnc retrofit.
    The problem is the z axis.
    I mounted the dmm servo motor with brake on the the z axis.
    I use 24v power supply only for the brake itself.
    The problem is when i turn on the computer and mach 3 software
    THEN i turn on the servo motor it drop down.
    Im using the 30mm ballscrew,1 kw with brake dmn AC servo motor.
    Is it the software setting in mach3 or tuning servo motor in dmm tuning software that i miss.
    Thank you mactec54.
    15362
    Hi mactec,
    Thank you mactec54.
    When the servo is energized the brake should release if the servo can not hold the load, it may be tuning try and add some more Gain but this must be a balance of the 3 settings
    If the servo can't hold the load after changing the Parameters, then you may need a counter balance of some kind to help with the load
    Mactec54
    Apr 2020
    maybe output of servo (U,V,W) damge.
    https://phitruongauto.com
    Jun 2014
    12
    I ll try to follow your advice.Thank you mactec.
    Dec 2003
    24221
    One engineering mistake in my book is aluminum spiral motor couplings, I reserve these for encoders.
    For motor drive, you are better off with stainless versions for durability.IMO.
    Al..
    Albert E.
    Jun 2014
    12
    Al..
    Hi Al_the_man
    Yes the aluminium coupler , a freind recomended me that type of coupler.this is the first time im working with servo motor.a lot of thing i did not know.
    Any particular type of coupler that you would recommend?
    Dec 2003
    24221
    The same version, but in stainless, if you are going to use the existing ones i suggest you get a couple of spares, you may need them. .
    Al.
    Albert E.
    Jun 2014
    12
    Al.
    Noted .1 bought 4 of it.1 got one spare.
    In case if something .....
    Stainless usually a bit expensive .
    Thank you al.
    Aug 2009
    1573
    ... multivariate of how to do the job for sure. Engineers have many choices
    https://www.mcmaster.com/standard-shaft-couplings
    Do you have any wiring diagrams of your setup? may help Color code?
    Jun 2014
    12
    Hi machinehop5,
    I manage to tune up the servo with the tuning software provided by dmm.
    I tune it to rigid in the tuning section with before i tune it to be standard.
    So the the problem which i had is solve.
    I used to work with stepper motor never with servo motor.
    Now the problem is when i switch off the computer , mach 3 and the servo power everything stand still until i turn the computer, i turn on mach 3 , i push the reset button on mach 3.the z axis drop.
    Luckily it have the stopper if not the ball bearing going to spread on the floor.
    I already power the servo brake with 24v 3a.
    Just that i need a advice on the servo motor diagram , how to wire it properly, or as long that the z axis wont fall.
    Thank you.
Page 1 of 2 12
  1. Yaskawa SGDH and SGDA servo motor/drive wiring questions
    By rpseguin in forum Servo Motors / Drives
    Last Post: 08-30-2021, 04:57 PM
  2. Kuka robot servo drive wiring
    By MarcNach in forum Servo Motors / Drives
    Last Post: 12-07-2018, 01:41 PM
  3. Servo amplifier/drive input wiring assistance please
    By dazp1976 in forum Benchtop Machines
    Last Post: 04-18-2018, 05:44 PM
  4. Problem in initial setup of TECO SERVO JSDEP, Servo Drive.
    By RanaAli in forum DNC Problems and Solutions
    Last Post: 03-21-2017, 05:28 AM
  5. 1979 model SL-1 yaskawa servo drive and servo problem
    By Redzilla in forum Mori Seiki lathes
    Last Post: 10-31-2016, 07:21 PM
