586,032 active members*
2,959 visitors online*
    Apr 2018
    30
    Editing custom_threads_xxx.txt
    I just tried added 1/4-40 and 3/8-32 model engineer threads to custom_threads_sae.txt and couldn't get it to work.
    I thought maybe the name was no good so just copied the 1/4 and 3/8 threads from threads_sae.txt over and changed the TPI and that didn't work either.
    I rebooted between each edit assuming PP loads the file once and doesn't refresh.
    I got what looked like two blank entries at the top of the threads list which then disappeared when I scrolled to the bottom and back to the top. I couldn't get the threads to show in either mill or RapidTurn PP.
    Am I supposed to edit the file in the release directory, eg ~/v2.2.2/custom_threads_sae.txt? Or is the one read by PP somewhere else?
    Dec 2008
    740
    Re: Editing custom_threads_xxx.txt
    I don't use them but I just tried with v2.1.6 by editing the file under ~/gcode/thread_data/ (not in the release directory) and it seemed to work fine.
    Step
    Apr 2018
    30
    Thanks TurboStep, you're right.
  1. Editing of PostProc
    By MarcW in forum EdgeCam
    Last Post: 06-12-2019, 12:25 PM
  2. Editing 3d clipart
    By 921X0 in forum Aspire
    Last Post: 03-04-2019, 11:46 PM
  3. Replies: 0
    Last Post: 02-22-2019, 05:31 PM
  4. Help editing post
    By dkrenfrow in forum Mastercam
    Last Post: 04-12-2012, 09:10 PM
  5. Editing G81 macro
    By flannman in forum Mach Wizards, Macros, & Addons
    Last Post: 02-12-2011, 08:20 PM
