586,103 active members*
3,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Advice needed on Fadal 3016 way condition
    Feb 2015
    31
    I'm the new owner of a '98 Fadal 3016, and while I've designed a lot of machined parts and made more than a few myself, this is my first 'real' machine tool (the predecessor to this was a CNCed RF45 that was more project than part maker).
    So far, the machine has had power for a week, but is still waiting for me to finish wiring the compressor control box and VFD to get air. Most of these photos were taken at the start of or during cleaning it out, which occupied most of last week, and this week I've been helping a family member replace the two air conditioners in my house, so limited progress.
    Album of install and machine here: Fadal 3016 - Album on Imgur
    So, the good to start:
    1. Everything (electrical) runs.
    2. Y and Z ways are clean (except for back few inches of Y ways, which have rust).
    3. Oil lines are intact and working.
    4. -5A controller.
    5. Rigid tapping.
    6. Spindle runout looks good (need to run a tenths indicator on it now), and spindle feels well lubricated and smooth.
    The bad:
    1. Way covers are beat up and rusty, nothing that can't be fixed as far as I can tell though.
    2. The table is out 0.0065 over the X, 0.003 over the Y. Everything slopes down from the back right corner, front left corner is lowest.
    3. The ends of the X-axis ways look bad. Really bad to me, but I'm hoping to be wrong.
    4. I strongly suspect there are Turcite issues based on #2 and #3, but haven't had a chance to pull the table off yet. I don't see Turcite peeking out the ends of anything.
    5. Backlash settings on the machine were X 8, 10, 14; Y 18, 20, 20; Z 20. I haven't confirmed these across the range yet, but my initial numbers at the center of X and Y were 0.002 and 0.0035" respectively. The X sounds like it has a bad bearing (but maybe that's cast iron dragging where Turcite is gone?). I'm gonna go through and start checking couplings and stuff, then replace bearings if that doesn't help.
    Most of the stuff I want to make on this probably doesn't care about the table being out, and I can always drop a fixture plate on top and skim it to match. But,I'm assuming if there's missing Turcite there is no reason to continue running the machine as is, so correct me if I'm wrong.
    If the Turcite needs fixed I will probably hand it off to a professional to do (for the same reason I'm not a good welder, I suspect I'm not gonna be able to focus long enough to get a skill like scraping down). I've found a couple places within driving range to take it to (but I won't turn away suggestions).
    Million dollar question is, do the X axis ways need reground? Is there something else I should measure to determine it?
    Apr 2016
    74
    Re: Advice needed on Fadal 3016 way condition
    We have 5 fadal vmc here. Only one did we have to replace the Turcite. From the picture it looks like it is at the end of travel.
    IMO, i believe if you clean that area up and do replace and scrape the Turcite, that should be good.
    One thing you might check (i know you have many things to do) check the tension on the pull knob.
    That is the only real issue that comes up...belleville washers.
    good Luck!
    Mar 2019
    12
    There is a guy on here right now that just did a turcite job himself and it didn't go so well the first time, but it is a learning curve and you can always learn from others. If where the turcite rides on the actual travel of the ways you cannot feel any grooves/scratches with a finger nail you are in good shape. You can, at the very least, clean and prep the machine and order any new parts you need to control the cost. And if someone nearby knows how to scrape properly they can help you out. I don't recall what the actual length of the turcite is, but on a cnc lathe saddle that I did turcite on we were able to machine it will a fly cutter in bridgeport and do the oil grooves with a ball mill. We went as far as to make sure his mill's table was square with headstock and no droop to it and everything before hand. In the end of the day I am within .002 on height of centerline and can hold .001 all day for tolerance. It had some grooving issues and I didn't bother with it. Just stoned it and took various measurements to see how much we needed to take of turcite to get it back to factory(.062 thickness turcite machined down to .048??)/
    I am about to load my new to me 4020 in the shed tomorrow finally and will start a thread with my discoveries, fixes, and modifications along the way for others and hopefully you can do the same.
    Jan 2015
    417
    This is how the table was made flat at the factory during the assembly
    https://www.youtube.com/watch?v=-FwTAEv8_EQ
  1. Vise size for a Fadal 3016
    By Recoil6 in forum Fadal
    Last Post: 04-07-2019, 05:51 AM
  2. WTB Fadal VMC-3016 or VMC-15
    Last Post: 06-14-2018, 07:18 AM
  3. Fadal VMC 3016 I Need Help PLEASE!
    By HBZ USA in forum Fadal
    Last Post: 08-07-2010, 07:11 PM
  4. Fadal VMC-3016 with 20 tool DATC
    By jonthebrit in forum Fadal
    Last Post: 04-15-2010, 01:36 PM
  5. Wiring a '96 Fadal 3016 to a RPC
    By FadalNewbie in forum Fadal
    Last Post: 09-25-2009, 11:21 PM
