586,062 active members*
4,608 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Not Getting Straight/ Smooth Diagonal lines or Smooth Circles Anymore
Results 1 to 9 of 9
    Question Not Getting Straight/ Smooth Diagonal lines or Smooth Circles Anymore
    Hi there!
    I have a Velox 5050 & my diagonal lines & circles are not cutting/ engraving straight. They are wobbly/ wavey & the machine feels a bit jerky when cutting/ engraving those diagonals & circles. I use autocad 2018 to create the linework & vcarve pro to create the code. I don't think the problem is coming from there. It seems to have gotten worse lately.
    Maybe mechanical? Could it be CV settings or motor tuning? I use the Mach3 profile that came with the machine? I'm fairly new to cnc (about a year) & I was just asked to do work for a day spa & of course now I'm noticing the lines are not coming out straight :/
    Some General info: 2 legs of the machine have wood shims under to level, but I checked recently & it's not perfectly level anymore, but it's not bad. I will re-level it.
    Any thoughts would be greatly appreciated! Thanks so much,
    Simon
    Re: Not Getting Straight/ Smooth Diagonal lines or Smooth Circles Anymore
    Mechanical - Something is loose on your machine.
    Thanks Ger, I appreciate the reply! Do you know which part is loose? Just joking, but I will sit down, clean & check every part of it this weekend. Thanks again for the quick reply!
    Start at the spindle, and work backwards.
    Jul 2017
    57
    Thanks for this thread. I think I have the same mechanical issue.
    Quote Originally Posted by Gallen66 View Post
    Hey Gallen,
    For my problem ger21 was right. I had a handful of screws loose at the spindle and the whole assembly rocked back & forth a bit. I attached a pic.
    Once I tightened them up everything was perfect!
    Hope this helps or you've already solved it!
    Hey Ger!
    That was exactly the problem and right where you said to check first. Tightened, cleaned, greased everything and it's running perfectly again! Made a maintenance checklist & schedule as well! Still learning...
    Thanks for taking the time to read & reply, you were such a big help. Greatly appreciated!
    Simon
    Jul 2017
    57
    Yes,
    I discovered that I had some loose screws on my ballscrew end mounts. That has made all the difference. I’ve had screws loosen before and have discovered it’s handy to use threadlock on bolts and screws that frequently come loose
    Good advice, I'll definitely pic some up, thanks!
  1. Laser cuts straight lines slower than curves or circles.
    By MCobb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-23-2018, 03:27 AM
  2. tb6560 x axis is grinding y is smooth z is smooth im a newbie
    By Hotrod10 in forum Stepper Motors / Drives
    Last Post: 04-16-2015, 05:11 AM
  3. Circles and arcs not smooth
    By Sheepspeed in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-24-2014, 10:23 PM
  4. Could anyone tell me why my circles do not come out round anymore?
    By TheWorkshopGuy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-13-2013, 04:02 PM
