HY01D523B VFD not working.
Hi Guys,
Due to life getting in the way of Life, I haven't been around the Zone for a Year or two.
Getting back to the Machine last month revealed an issue with the VFD/Spindle System.
I went to start the Spindle and found that the VFD appears not to be booting up!
The Power LED is on and the Cooling Fan runs, but there is neither a Display nor Spindle action happening. The VFD doesn't respond to any Button presses.
As the Display isn't showing, I cannot determine any specific Errors.
The System was working when I shut the CNC Machine down about 6 Months before.
The VFD/Spindle is stand-alone and is not connected to Mach3 nor the PC.
I've checked all the Wiring and Connections just in case, and all is sound.
I've opened the VFD up and removed the Display Board and the next Board in the Stack, (haven't got to removing the Board attached to the Heat-Sink yet), but there is no obvious damage to any of the 3 Boards.
Has this happened to anyone before, and is there a possible solution to the Issue apart from purchasing a new VFD?
Thanks in advance ....
Murray.
Skype me on imagineeringnz
Intuitor: (noun)
A person with a passion for learning and innovating that is so strong it is often more powerful than the desire to eat, sleep or seek personal wealth.
Ummm . . . Guilty as charged.
