586,115 active members*
3,397 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3020 Chinese power supply needed / can I get the bits to build one?
Results 1 to 16 of 16
    Sep 2016
    29
    Hi everybody, totally snookered, my Chinese 3020 power supply finally gave up the ghost yesterday and is totally beyond repair.
    Is there anyone out there that has a power supply for the 3 Axis machine?
    Is there anyone out there who could tell me how to build (put together) an equivalent power supply.
    I am full of confidence in my fellow CNC'ers.
    Best regards
    Mar 2007
    2083
    Re: 3020 Chinese power supply needed / can I get the bits to build one?
    why do you think your power supply is totally beyond repair.?
    is the power supply a switch mode power supply or
    a linear power supply ?
    different manufactures build their own versions of the Chinese 3020 machines
    using different electronics
    a photo of the power supply , stepper drivers and spindle drive will help
    john
    Sep 2016
    29
    Thank you John, I will get some further information together: In the meantime here are a few photo's of the suspect board. This power supply let me down before and I replaced a mosfet chip and it was ok. This time I replaced the Mosfet chip again and it hasn't solved the problem. Hence my thoughts being the power supply is beyond salvage. Any advice gratefully received.
    Best regards,
    Custer
    Mar 2007
    2083
    looking at your photos
    it looks like the FET is not fastened to the heat sink and may of over heated
    it looks like the resistors used to measure the motor current and limit the current through the opto isolators LED are OK
    I will have a look for the diagrams of the board and post more tomorrow
    John
    Sep 2016
    29
    Hi John, the FET was disconnected at that time ready to solder a new one in place.
    Here are some more photo's.
    Many thanks for all your help.
    Best regards,
    Custer
    Mar 2007
    2083
    from a post here on cnczone
    YooCNC 3020 ZD - Spindle PCB
    Attachment 419342
    another version off the net
    Attachment 419340
    depending on your local mains voltage the DC supply to the spindle could be 50 to 60V depending on the load on the spindle
    ( stepdown transformer 220V to 36V AC multiply by root 2 for rectified DC voltage = 50V DC
    in my location mains supply is 243V to 248V depending on time of day DC supply
    at 248V would be 57V DC - depending on the transformer regulation off load the transformer output could be 6 to 10% more ! )
    if you bought or made a PWM speed control it may have to work with a 70V DC supply
    possible ebay control ?
    Attachment 419364
    https://www.ebay.co.uk/itm/DC-PWM-Mo...2aba%7Ciid%3A1
    john
    PS
    whats the length and width of the board ?
    PPS
    I see you posted as I was typing
    and the loose FET was a red herring
    Sep 2016
    29
    Hello again John, the physical board size is 12cms x 5.5cms.
    Thank you for the other information but I have no idea what it means, sorry but electronics and me don't mix.
    Best regards,
    Custer
    Mar 2007
    2083
    do you have a multimeter ?
    if so check you have about 50V dc at fuse 1 and the two 1 ohm resistors in parallel measures 0.5 ohms
    while a faulty FET can be the problem
    some times the 8 pin IC (NE555) can fail to drive the FET gate with the PWM signal to turn the FET ON so the spindle does not run
    from another post when I helped a member rewire a 120V machine to 220V
    this is the transformer used
    Attachment 419390
    the spindle power supply from post 6
    Attachment 419392
    john
    Sep 2016
    29
    John I'm so sorry I fear I have lead you down the wrong path, you see the spindle is running at full speed all the time, as soon as the power switch is on, and there is no difference when the spindle switch is on or off, neither does the emergency stop button do anything, the spindle just keeps going.
    So sorry I didn't make myself clear.
    Best regards
    Custer
    Mar 2007
    2083
    if it running at full speed
    either the FET is short circuit between source and drain
    or the NE555 IC output is high (+4 to 10V)
    the FET is turned on when the gate is +4V or more with respect to the source
    normally the NE555 switches between 0V and +12V
    the speed control adjusts the ratio of on to off time (the longer its on the faster the spindle runs)
    john
    Sep 2016
    29
    Hi John, I have tried to do the tests you asked and if I have done them correct then the results are:Across fuse 1 I have a reading of .025
    across the the 1 ohm resistors it is 0.00 this is with a very small digital multimeter I have had for years and not confident in it's use.
    Best regards
    Custer
    Sep 2016
    29
    Hi John, what I have done is ordered a new FET and a new 555 chip I am hoping that after a bit of soldering this weekend I should be up and running again.
    I will keep you informed of any progress (or lack of it).
    Best regards
    Custer
    Sep 2016
    29
    Hi John, all I can say is you are a STAR. The new FET and NE555 chips turned up this morning so I soldered the new FET in place, tested it and everything WORKED without even having to solder the new NE555 into place.
    YIPPEEEE.
    Best regards
    Mar 2007
    2083
    good to know its working
    john
    Jan 2007
    626
    Nice work John!
    I am very jealous of that skill.....
    Steve
    Mar 2007
    2083
    this should help with the repair of the spindle speed control
Name:	3020 spindle power supply.jpg
    John
  1. Help with Chinese power supply
    By ALcncFinland in forum Machinery Manuals / Brochures
    Last Post: 08-18-2017, 05:09 PM
  2. 50w laser chinese power supply
    By toons666 in forum Laser Hardware
    Last Post: 07-25-2017, 10:02 AM
  3. Replies: 6
    Last Post: 10-28-2014, 10:51 AM
  4. controlling chinese laser power supply
    By dominicburke200 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-02-2014, 10:34 PM
  5. Chinese Power Supply connections
    By thudson in forum CNC Machine Related Electronics
    Last Post: 03-20-2010, 04:29 AM
