586,647 active members*
2,059 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alarm 2 on A06B 6079 H201 servo drive
Results 1 to 7 of 7
    Apr 2012
    79
    Hi, I have got a machine with an alarm number 2 on the A06B 6079 H201 servo drive which does not appear if I turn the machine on without connectors JX1A and JX1B connected. If I connect either one it will start up with the alarm 2. Both servos and encoders are connected so I am assuming there is not an issue with them. My main question is does anybody know if this is a servo drive fault or could it be something else? I have attached a couple of photos to show the issue.
    Thank you
    Attachment 419366Attachment 419368
    Re: Alarm 2 on A06B 6079 H201 servo drive
    The problem you have is within the servo amp and is quite common on the 6079 series.
    Apr 2012
    79
    Hi Tristarcnc. Thanks for the reply. I have checked the capacitors and replaced the 621 opto, c4151 transistor but had no affect. There is a 15v regulator which I haven’t checked yet. As it’s the 5v supply that’s the issue (I think) would you mind pointing me in the right direction.
    Thank you
    May 2016
    526
    What machine is it on ?
    Apr 2012
    79
    Quote Originally Posted by mbservice View Post
    Hi. It’s a Fanuc Robocut Alpha 0-C with a 16-WC control. It’s new to me and was purchased knowing it had this fault.
    Quote Originally Posted by tristarcnc View Post
    Merhaba bende ayn? alarm? çözmeye çal???yorum. IPM mi drgi?tirmem laz?m. Nas?l tamir edebilirim.
    Apr 2022
    13
    Quote Originally Posted by Lomach View Post
    Hello, how did you repair that? I have similar failures in my drive. It says low voltage in the manual, but its the only servodrive where I have that problem so its not a voltage input problem.
  1. WTB fanuc alpha drive a06b 6079
    By lowcountrycamo in forum Want To Buy...Need help!
    Last Post: 03-08-2017, 04:29 AM
  2. A06B-6079-H305 DC HV input limits?
    By Sotris in forum Fanuc
    Last Post: 01-31-2017, 02:49 PM
  3. Alpha Series Servo Amplifier A06B-6079-H106
    By M.RISHIKESH in forum Fanuc
    Last Post: 11-25-2009, 04:12 AM
