586,598 active members*
3,543 visitors online*
    Sep 2009
    277
    What power tube for mixed use?
    Hey guys
    I am building my laser qith 50w tube which is capable to a point. Ot can cut 3mm acrylic and 10mm ply and 6mm acrylic and it can engrave.
    Now from what inhave seen most people seem to be using less than 100w of they engrave etc as the power is more controllable at the low end.
    Is this fact and then should i go to 80 or 90w when I upgrade
    Sent from my SM-N960F using Tapatalk
    Aug 2005
    108
    Re: What power tube for mixed use?
    Hi, with 50W u will cut 6 to 8mm acrylic and 3mm MDF with good finishing and prefect engraving. 80/90W 12 to 14mm acrylic 6mm mdf ( 8mm with low speed and some burn) good engraving . High power tubes is no good to delicate engrave. Wood need be cut at high speed as possible or you will get charcoal for barbecue.... so, wood need power.
    Sep 2009
    277
    Quote Originally Posted by oneeye View Post
    So 90w is a good maximum?
    Aug 2005
    108
    80/90W tube is nice to normal cut and engraving.
    Sep 2009
    277
  1. power of laser tube
    By Junaidzia in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2017, 11:22 AM
  2. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  3. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
  4. How much power is your tube actually producing?
    By ELaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2015, 01:11 PM
  5. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
