586,111 active members*
3,645 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > can the tailstock be programmed on Daewoo puma 230m
    Mar 2006
    8
    I have a Daewoo Puma 230m(c-axis) with a fanuc 21i-TB control
    Can I program the tailstock within the part program? My software just put a M00 and a coment to say advance tailstock.
    If it can be done does anyone know the proceedure?
    BigBill
    Aug 2005
    578
    Sure it can. Have a look in your manual for the M code. I know the tailstock on my 220a can...
    2932
    Check Keep Relay #9 bit 5. If it's a 1, you have the "programmable" tailstock.
    Position Z over the "traction bar" (probably Z home)
    M46 extends the traction bar and unclamps the tailstock.
    Move Z to the desired position.
    M47 retracts the traction bar and clamps the tailstock body.
    M78 and M79 are the quill forward and retract commands.
    M31 allows the tailstock to move with the spindle turning.
  1. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  2. Daewoo Puma 700 LM - Lathe
    By Kim in forum Daewoo/Doosan
    Last Post: 04-18-2008, 07:18 PM
  3. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
  4. Daewoo Puma 200c W/18t.
    By JIMMYZ in forum Daewoo/Doosan
    Last Post: 10-26-2006, 04:10 PM
  5. Daewoo Puma Service
    By active-precision in forum Daewoo/Doosan
    Last Post: 09-21-2005, 12:11 PM
