586,036 active members*
3,817 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Formatting Bobcad setup sheets
    Apr 2016
    102
    Does anyone know how to format BobCAD setup sheets so as that the various boxes relating to operations are not split over page breaks?
    I have attached a typical example, I guess I am quite old school in that I would like decent printed setup sheets in my workshop.
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Dec 2008
    4548
    Quote Originally Posted by Bazzer View Post
    Barrie
    Hey Barrie,
    So i have never seen bobcad output like that. Is that how you get it out of bobcad? It looks like a pdf printer is messing with how pagebreaks are happening...
    Is bobcads setup sheet generator outputimg pdf now, or did you use a pdf printer for that....?
    Apr 2016
    102
    Re: Formatting Bobcad setup sheets
    Hello Burrman
    I used a PDF printer to enable the problem to be uploaded but exactly the same thing happens when printing to a windows printer either Kodak or more recently HP 7612.
    No page breaks as you say.
    Do you get page breaks?
    regards
    Barrie
    Dec 2008
    4548
    Hello Burrman
    regards
    Barrie
    I understand now Barrie, i was just looking at the output from BobCad.
    Let me do some printing and see if i can find anything that helps.....
  1. BobCad V26 setup sheets not correct
    By Big Chips in forum BobCad-Cam
    Last Post: 02-26-2014, 10:25 AM
  2. Better Setup Sheets?
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 11-01-2011, 05:19 PM
  3. X2 AND X3 SETUP SHEETS
    By CNC_BOB in forum Mastercam
    Last Post: 03-06-2010, 02:42 AM
  4. X4 Setup sheets
    By 72k5 in forum Mastercam
    Last Post: 03-04-2010, 07:55 PM
  5. Setup sheets
    By laka in forum Uncategorised CAM Discussion
    Last Post: 09-18-2008, 07:10 PM
