I wanted to update everyone on my current FS0 Model B build from past history. Some of it has changed quite a bit from previous.
Control Unit: A02B-0091-B501
Master Board: A16B-1010-0286
PSU: A16B-1210-0510-0
Graphics: A16B-1210-0800
PMC: A16B-1211-0901 PMC-M (Electroic ROM)
I/O: Use I/O C7 A16B-1211-0300 I/O C3
Cassette: Macro Cassette B A02B-0091-C113 (128kB Macro Executor) or you could use A02B-0091-C115 if you need more room at 256kB which should be fine. I used C113
Order Made Macro A02B-0091-J550
CRT/MDI unit: A02B-0091-C042
Operator Panel: A02B-0091-C141
Operator Panel interface board:
Servo Amplifier: 3x AC S Series 5S Type A06B-6058-H006 (you could use H005)
Servo: AC S Series Servo Motor: A06B-0314-B002
Spindle Amplifier: AC S Series A06B-6059-H002
Spindle Servo: AS S Series Spindle Servo 6S Type A06B-0758-B100 (3Ph 200V 5.5kW/7kW 1500/6000RPM)
You can use this guide to configure your Series 0 Model B and this installatioun should work for both M and T model types.+
Install a I/O unit Model A: A03B-0801 and it's backplane, powersupply and interface unit IF01A. (See B-61813 or GFZ-61813) ; Prefereably A03B-0801-C009 thats what I used ; PSU is A16B-1310-0010. IF01A is A03B-0801-C101
You will need a FANUC Transformer A80L-0001 and/or A80L-0026 type
You will also need a FANUC Input unit A14B-0061 or A14B-0076 I forget which one works best. Anyone know which to use?
You can add a FANUC Pulse Generator (Jog Handwheel Knob) A860L-0201-T001 or T002. (build a box for this one or put it on your cabinet)
Position Coders are A86L-0026-0002#0002 (Max 6000RPM)
The cabinet might need a heat exhanger: A02B-0094-C901 and maybe a FANUC Fan Unit.
I would use a suitable Hoffmann or Hubbell enclosure. I prefer floor standing double door cabinets, 60" high. A single door cabinet would be fine. You can also use smaller door type cabinets. I can provide details on what I used.
If you need parameters I can supply you with a basic set of parameters you MUST modify/tailor to your needs. Does NOT include option parameters, these you will have to have set by FANUC.
This installation should be good for both M and T controls.
