586,068 active members*
4,238 visitors online*
    May 2007
    32
    RFQ - 2D Part - Steel Laser Cut OR Aluminum CNC Router
    I need this for a simple mock up job. Either Laser Cut or probably better would be waterjet from steel plate, or CNC from thicker Aluminum. I just need it to be stiff enough to make sure my dimensions and stuff are correct, so I think 3/16" Plate (maybe even 1/8") or 1/4" Aluminum would be fine.
    Units are mm, the lower holes are 192mm apart, the closer ones are 140mm apart, and they're 8.5mm offset.
    I need 1 piece for sure, maybe 2 depending on cost.
    Message me here, or post here. Need these sooner than later.
    Feb 2018
    21
    Re: RFQ - 2D Part - Steel Laser Cut OR Aluminum CNC Router
    PM sent...Pls check your inbox
    PM sent
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    May 2007
    32
    RFQ is now closed. It has been awarded.
    Thank you to all those who quoted.
  1. Steel / aluminum CNC router design
    By Reinier in forum DIY CNC Router Table Machines
    Last Post: 02-15-2018, 12:16 PM
  2. 4x4' router - aluminum and steel frame
    By mbronkalla in forum DIY CNC Router Table Machines
    Last Post: 01-13-2016, 02:45 AM
  3. Laser to cut 1mm Alu, mild steel, and aluminum
    By oxus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2012, 12:40 AM
  4. RFQ - CNC Machined Steel & Aluminum Part
    By HighCaliber in forum Employment Opportunity
    Last Post: 07-21-2010, 07:38 PM
  5. Steel/Aluminum Door Router Log!
    By boguski.1 in forum CNC Wood Router Project Log
    Last Post: 04-16-2009, 11:04 AM
