586,560 active members*
3,879 visitors online*
Results 1 to 5 of 5
    Mar 2011
    357
    noisy motor help
    I have 4 of the 5 amp 570 in/oz nema 23 steppers. I finally got my machine up and running but I am having an issue with one of the motors.
    If I only have my Z, Y and A motors plugged in all is well but when I plug in my X motor ALL the motors start to make a kind of hissing,buzzing noise at idle.
    Unplug the X motor and all go quiet. Plug it back in and all get noisy.
    Here is a grid of what I have tried
    Motors plugged in
    A X Y Z noisy
    X Y Z noisy
    A Y Z quiet
    AX noisy
    AXY noisy
    XY noisy
    XYZ noisy
    YZ quiet
    So you can see the only time the motors get noisy is when the X motor is plugged in.
    I am using KL 5056 E drivers
    I am running Arduino/GRBL
    The X and A drivers are connected to the same port on the arduino.
    I think I have a bad motor.
    Please help.
    Mar 2011
    357
    Re: noisy motor help
    no replies from automation tech?
    35538
    Quote Originally Posted by tkms002 View Post
    If you want tech support, email them directly. That's always the best method, for any company.
    35538
    This is possibly the issue. Swap the X motor and drive with one of the others, and see if the same thing happens when you add the 4th motor.
    Mar 2011
    357
    Ok. It does not matter what driver the X motor is plugged in to. It causes the noise when connected to any of them.
  1. Motor/stepper issue : blocking, slowing down, being noisy
    By nicolasd5150 in forum Mach Software (ArtSoft software)
    Last Post: 04-27-2015, 04:37 PM
  2. Drove gantry into hard stop, now stepper motor is very noisy
    By N2950H in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-23-2015, 02:12 PM
  3. Noisy z axis
    By forseral in forum K2CNC
    Last Post: 04-12-2012, 01:47 AM
  4. Noisy rack
    By Robin Hewitt in forum Waterjet General Topics
    Last Post: 10-10-2007, 07:00 PM
  5. Noisy J2 head
    By Healey in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2007, 11:17 PM
