Re: tormach limitation, or am I doing something wrong?
Originally Posted by
Snecx
I had this problem with Haimer and the TTS holder for it. The concentricity of the tip always go off by +/-0.01mm after a while, but not immediate like yours did.
Snecx
Unfortunately I don't have good news for you as I have pretty much given up on my Haimer. I use the Hallmark ITTP now and that has been a great piece of equipment.
I hope you will find a solution for your Haimer soon.
Wait a minute. That's less than 4 tenths. Isn't that far better than the machine itself? Isn't anything less than 5 tenths considered pretty good for general machining?
If the Haimer isn't working for you what do you go with instead?
One option with electronic edge finders is to probe twice 180 degrees out, and then do the math. Even then unless you have a really really high end probe you could still be +/- a couple tenths. I've tested this by auto probing hole centers with am electronic probe. Cheap ones and mid range ones. Never had a high end one.
Bob La Londe
http://www.YumaBassMan.com
