586,389 active members*
2,952 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, how do you check the excentricity for turning tools ?
Results 1 to 1 of 1
    Jun 2015
    4154
    hello, i recently setup some small parts on a 250mm chuck, and for few operations i use gang/small tools; i have to align them on center pretty well, because they are fragile
    i also noticed that 25mm shank tools do have the cutting edge at height 25±0.25, while i was expecting 25±0.1
    please, how do you check the alignment, besides cutting a face ? i mean do you use a faster method, which does not involve cutting ? like attached things ? do you know what is their precision, are they reliable ?
    image 01 : requires to have cilindrical jaws at a certain position, in order to clamp the device; such jaws should clamp without tir, at least where the bubble is located ( = downtime with jaws preparation, and jaws set-up; is faster to face-cut )
    image 02 & 03 : are not for bent sleighs, but for horizontal
    kindly
  1. Replies: 2
    Last Post: 09-27-2017, 08:12 AM
  2. Best tooling prices for swiss turning tools
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 08-04-2017, 05:03 PM
  3. cycle stability inspection
    By deadlykitten in forum Okuma
    Last Post: 01-12-2017, 08:22 PM
  4. CNC Vertial Turning Tools
    By yifei in forum Want To Buy...Need help!
    Last Post: 04-01-2012, 07:36 AM
  5. TURNING TOOLS!
    By didzbartholome in forum CNC Tooling
    Last Post: 09-21-2011, 11:21 AM
