586,036 active members*
3,817 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )
    Jun 2015
    4154
    hello, i recently setup some small parts on a 250mm chuck, and for few operations i use gang/small tools; i have to align them on center pretty well, because they are fragile
    i also noticed that 25mm shank tools do have the cutting edge at height 25±0.25, while i was expecting 25±0.1
    please, how do you check the alignment, besides cutting a face ? i mean do you use a faster method, which does not involve cutting ? like attached things ? do you know what is their precision, are they reliable ?
    image 01 : requires to have cilindrical jaws at a certain position, in order to clamp the device; such jaws should clamp without tir, at least where the bubble is located ( = downtime with jaws preparation, and jaws set-up; is faster to face-cut )
    image 02 & 03 : are not for bent sleighs, but for horizontal
    kindly
    Dec 2013
    5717
    Re: please, how do you check the excentricity for turning tools ? ( cnc, tilted saddl
    I use a 0.625'' dowel pin in the chuck or collet. Measure the tool height with a height gauge, measure the station height with gauge blocks, subtract the difference and add the pin radius, and that is the required shims to put the tool point on the spindle center line.
    Then I store the dimensions on the computer with this screen in my program. Inputting the tool height and station height and clicking Apply calculates the required shims.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2015
    410
    I found this on the internet and made one myself. If the lathe is horizontal, it works like a dream,
    Nov 2017
    591
    Quote Originally Posted by hfjbuis View Post
    Interesting. Actually not limited to horizontal x travel. Could be designed to account for slant bed if you know the exact angle. I think I'll make one for my mill turn setup which has vertical x travel when turning. The bubble level just needs to be horizontal when the stop is resting on the tool tip. Luckily for me, I don't need to trial and error with shims. Jog it in to level with 3rd axis
    Jun 2015
    4154
    yes, i could craft one, but i wish to buy it / kindly
  1. Replies: 0
    Last Post: 05-12-2019, 10:29 AM
  2. Replies: 2
    Last Post: 09-27-2017, 08:12 AM
  3. cycle stability inspection
    By deadlykitten in forum Okuma
    Last Post: 01-12-2017, 08:22 PM
  4. CNC Vertial Turning Tools
    By yifei in forum Want To Buy...Need help!
    Last Post: 04-01-2012, 07:36 AM
  5. TURNING TOOLS!
    By didzbartholome in forum CNC Tooling
    Last Post: 09-21-2011, 11:21 AM
