586,094 active members*
4,137 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Apr 2011
    720
    Cool Polycarbonate - off topic
    All;
    I know this isn't really a Tormach question, but I don't post on that many forums, and this is about as close as I could get.
    I need to place some small magnets ( 3/8") into bores in polycarbonate, and I'm looking for advice as to the best way to do it.
    My initial thought is a light press fit, but I have very limited experience with polycarbonate, and I'm concerned that this may cause micro cracks to develop over time and lead to failure.
    Is this a valid concern? My next thought was to epoxy the magnets in place.
    Any advice would be much appreciated.
    Terry
    Oct 2011
    477
    I use lots of small magnets in 3D Printed Assemblies.
    I find that a snug fit, as in finger tight with water thin ACC adhesive works very well. I would share your concerns with a press fit.
    I also print polycarbonate, makes very durable assemblies.
    Gary
    Quote Originally Posted by MFchief View Post
    All;
    Terry
    Apr 2011
    720
    Re: Polycarbonate - off topic
    Thanks Gary, I like your approach, think that I will try that first.
    I am milling one part that will be held in place magnetically to another one that I had planned to print in PLA. I've never used a polycarbonate filament before. Any advantages over PLA? I assume that the poly filament will work with standard printers, temps, diameter, etc.
    Terry
    Apr 2008
    19
    Have you considered epoxy?
    Apr 2011
    720
    I have, that was my second thought after the press fit.
    I just finished milling the first piece and the fit of the magnet in the hole is very close, I suspect I will have better luck on this one with the CA, because I don't believe I can get enough epoxy between the magnet and the poly to create a decent bond.
    Terry
    Apr 2008
    19
    Terry
    CA does not bond well to smooth surfaces. see this article.
    https://www.starbond.com/tutorials/w...dhere-well-to/
    Jan 2016
    99
    Fractures usually start around drilled holes. I use a propane torch to melt the edges of acrylic or plexiglass to head off later fractures. Lexan has a very fine point between melting the edge and burning. I don't know if any type of glue will prevent this.
    Rough drilling and boring may give a better surface finish that will not fracture.
    Dave
    Apr 2011
    720
    I have read various accounts that most common adhesives don't play well with polycarbonate, CA's and epoxies included. The stress relief of the torching sounds like it could help.
    I have room to put a plug behind the magnet, and plan to leave a small thin lip in front of the magnet to keep it from pulling out to the other magnet it faces. I hope that will do the job, it's not a super critical situation, so I think that will work.
    Terry
    Nov 2012
    591
    I haven't glu3e to PC, but I have glued to that really-slick stuff: acetal!
    The adhesive that works there is "show goo," which is made to waterproof hiking shoes. But ... it also bonds pretty well.
    Sounds like you have something that works, but if you need to experiment more, I'd recommend that!
    Feb 2006
    7063
    CA will work just fine, just make sure you don't over-do it, as it will make a mess of ANY surface it touches. Gorilla brand "Super Glue" is, by FAR, the best I've found for gluing to Acrylic and PolyCarbonate, and is thick enough to fill any small gaps. Many others will not stick at all. Applied to a machined surface, you will never be able to get the magnets out, without destroying the Poly.
    Regards,
    Ray L.
    Oct 2011
    477
    PC prints well but requires much higher temperatures. Usually 260 to 300 C for me but it is good stuff, about the same or a little better strength than nylon BUT more difficult to print.
    PC prints well on a PEI bed with the bed temps between 100 - 120 C.
    PC absorbs water and must be throughly dried. It also wants t
    o shrink and curl up on the bed. Requires planning and good design but it is good stuff for strength.
    Terry
    Apr 2011
    720
    Thanks for the tips Gary, I'm going to get some and play around with it.
    I have some Gorilla brand CA, that's what I plan to use, I'll let everyone know how it comes out. It will take a few days, Cura says it's going to take 20 hours to do the print I need, and I'm still fiddling with the CAD for the part.
    Terry
    Mar 2012
    189
    I affixed rare earth magnets into bores in Delrin with 3m VHB tape with good success. The magnets are 1/2" dia about 1/8" thick. I cut squares of the tape and applied to magnet, then removed the backing and trimmed overhanging corners while trying to not touch the back of the tape. Both magnet and plastic were cleaned with alcohol in advance. The bores need not be tight for this application. Previous attempt with CA glue met with magnets releasing from plastic.
    tape https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    -Jon
    Apr 2011
    720
    Thanks, if I can't get the glue to work, I could probably try the tape by sticking it to the plugs.
    Terry
    Feb 2018
    17
    If the design allows, you could also, spot the bottom of the hole with a drill, just deep enough to leave a dimple for epoxy to sit in.
    Apr 2011
    720
    On one half of the joints, I do have room for that, thanks.
    Terry
    Jan 2019
    You can press the magnets into a pocket and it will stay. I do this all the time. Just make a pocket about 0.005" smaller than the magnet. For instance I use 1/2" x .125 magnets and make a pocket of 0.495 x 0.130 deep and then press in the magnets. They do not fall out or cause cracks. I use 1/4" Poly. Just be sure to get your polarity correct because there is no taking it back without damaging the material.
    Mike
    Apr 2011
    720
    Hi everyone.
    Just wanted to close out this thread that I started a while back.
    As usual life got in the way of finishing this project and I just wrapped it up today. I 3D printed the dust boot which took 16 hrs, and naturally the first one messed up and I had to re-do it.
    But, I did finish it up today, and to the point of the original post, I ended up sizing the magnet pockets in the polycarbonate arms, and the associated pockets in the printed PLA body for a light press fit. It seems to be working fine, but time will tell if cracks start to develop. Good news is, with our hobby/business, I still have the files, so if need be, I can make new parts pretty quickly.
    As you can see in the attached pic, the boot is held to the arms just by the magnets, in order to facilitate quick bit changes on the router.
    Thank;s to everyone for your suggestions and ideas.
    Terry
    Oct 2011
    477
    Cool!
    Very nice looking job, what material was used to print the boot?
    Gary
    Hi everyone.
    Terry
    Jun 2014
    1780
    Attached ThumbnailsVery professional looking job, congrats!!
    mike sr
Page 1 of 2 12
  1. Seriously off topic
    By smittys800 in forum Haas Mills
    Last Post: 04-15-2008, 11:56 PM
  2. Off Topic, But Hopefully Interesting
    By vacpress in forum DNC Problems and Solutions
    Last Post: 12-24-2005, 08:05 PM
