586,655 active members*
2,355 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Getting single phase 220v and 110v from 3 phase 220v
Page 1 of 2 12
Results 1 to 20 of 30
    Aug 2013
    76
    Hello,
    Looking for suggestions to get single phase 220v for my servo drives as well as 110v single phase for the PC running the machine.
    Any suggestions are appreciated!
    Dec 2013
    5717
    Re: Getting single phase 220v and 110v from 3 phase 220v
    Assuming you are in North America, what is your 3 phase voltage? 208, 240, 480? There is no 220V in North America.
    I'm splitting hairs here because each case is different. See here https://ctlsys.com/support/electrica..._and_voltages/
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    76
    Will likely be 240v from an American rotory phase converter.
    Aug 2009
    1573
    May 2013
    480
    you likely do not need 120vac for your computer. many are 100-260vac, they take the incoming ac and convert it to 400 volts dc.
    the older computer power supplies have a switch you need to set for 120/240 operation. get it wrong and it blows up.
    you will need a transformer if you really do need 120 from from a 240v source.
    in the case of your rotary phase converter you have 120vac from line 1 and 2 to neutral. line 3 will read 208 volts to neutral. you can buy a 5 pin plug to handle that correctly but there is no guarantee that everyone has 120v line to ground on two of the phases. it could be 138 on all three phases, or it could be 120/208 for high leg delta (electrically a rotary phase converter and high leg delta is the same thing) so if your machine ever gets plugged into someone else's system there is no guarantee they had it wired up the same way, so there is a 1 in 3 chance you end up sending 208 into your 120v system.
    corner grounded delta won't have a neutral so there is no chance of your machine ever being plugged into that if you wire it up with a 5 pin plug.
    nema L21-20R for example.
    i'm not aware of plugs specifically for high leg delta (aka center tapped delta)
    Do you have single phase 240V available directly? If so, just run a 4 wire cord like a dryer cord, which will give you both 120V and 240V.
    15362
    Quote Originally Posted by PIVOTALCUSTOMS View Post
    The RPC most likely will smoke the servo drives, servo drives in general don't like RPC's a lot of servo drives will run on 220/240v single phase so what do you have for servo drives
    Mactec54
    Aug 2009
    1573
    Dec 2013
    5717
    You need the RPC to run your spindle? And if that's the case, why are you using single phase servo drives?
    But, coming off of the RPC you have the two normal single phase hot legs and the manufactured leg. I would use a 240/120 transformer across the 240 legs to derive the 120V, or power the computer from a completely separate circuit so you can use it without the RPC running. This is the way my lathe is set up.
    Since you're using single phase servo drives, also make sure they are wired to the 240V hot legs and not to the manufactured leg from the RPC.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1573
    Hello,
    Call a Pro...maybe Maytag repairman local
    Aug 2013
    76
    Sorry I mis-spoke, I am actually going to be using the PT-355 from Phase Perfect. I was originally looking at the ARC but the phase perfect seemed a much better application for the CNC.
    Anyhow, My retrofit has two single phase 220 Servo Drives on X and Y and a 220 three phase on the larger Z axis. The spindle Drive is also three phase.
    The PT-355 describes its output as follows:
    The converter shall be based on a double-IGBT conversion design, rectifying the
    incoming AC power to DC, then generating a third AC voltage which is added to
    the two legs of the single-phase service, producing balanced three-phase power
    in a closed delta configuration with a center-tap ground between two of the legs.
    This is where Im a bit unsure, I considered pulling a leg for 110 like i have done in the past on the RPC but i wasn't able to find alot of info on a Closed Delta Config, so im unsure if thats doable?
    If not is there a transformer config that can go 3 phase to 220 with neutral?
    Thanks for the info and sorry for the hasty post and lack of info.
    Dec 2013
    5717
    Well that changes things a bit. I think it's time for a chat with Phase Perfect tech support. Reading through the manual it looks to me like 120V could be derived from one leg to neutral, but I'm having a bit of a hard time getting my head around exactly what it says. Same with using two legs as a 240V single phase output, it seems like it would work but I'm not sure. I would prefer that they show a diagram of the wiring for those configurations. Like I said, talk to tech support for a real answer.
    Look at the Three Phase Four Wire Delta diagram from the link I posted above.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    76
    Thanks Jim,
    I will definitely give them a call tomorrow, thats where I was at as well but I wasn't sure if that was just due to my more limited understanding of all of this or if there documentation wasn't 100% clear.
    I will report back with their answers.
    15362
    He would need a Neutral wire to get 120v supply from the 240v source
    Depending on what size his spindle Hp is he may not need a RPC for his machine at all, so he needs posts what his spindle requirement's are and does it have a VFD Drive
    Mactec54
    Aug 2013
    76
    The spindle motor is a 5.5 kw 3phase servo spindle motor running a 3 phase pulse/direction drive.
    The servo for my z is also a dedicated 3phase drive.
    So as far as I can tell 3 phase is required.
    So after chatting with Phase Technologies the output is closed Delta 3 wire phase to phase 1% voltage with on leg being high phase to ground...
    The 220v servo drives are currently running 2 hot legs of 220v service no neutral in my test setup( the inputs are designed for oversees power 1 hot 220v leg 1 neutral)
    So could I in theory just run those from 2 low legs to ground with 220v between phase?
    That just leaves me with the 110v issue
    15362
    You need a neutral for 120v single phase which you can split from any of you main 240v supply if you live in NA then you have120 / 240v single phase supply not 220v
    Don't believe what they are telling you about the RPC, there is not an RPC made, does not matter what brand or manufacture they will not be even close to 1% even the CNC grade RPC
    No you can not run the low legs to Ground lots of smoke and Brakers would trip if you short a live wires of anything
    Now if you where talking Phase Perfect then there digital phase converter can easy give you clean 3Ph power @ 98% efficiency
    Who is the manufacture of the servo drive most 3Ph servo drives will run on single yours would be at the top of the range for single phase though but worth a try
    Mactec54
    15362
    Are that makes a big difference Phase Perfect is the way to go if you need 3ph power I have a PT380 you could get them to add a Neutral terminal block so you could run a Neutral for a 120v supply as well I did not but did not have a need for 120v
    You would take the 120v from one Hot leg that feeds the Phase Perfect and the Neutral and Ground would give you a normal 120v supply
    Mactec54
    Dec 2013
    5717
    You are correct in that you can't buy one off the shelf. But it's possible to build one Here is a picture of the panel meters on mine 1.01% or better under most operating conditions. T1-T3 is about 255 unloaded, but settles right down under any load. But a Phase Perfect would probably be better.
    239, 237, 239, 236 if you can't read the meters.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    1740
    Very impressive Jim. If the OP needs 5 amps or so 120 vac just install a transformer. We did it all the time on 3 phase MCC that used 120 vac for controls. FYI most PCs today will run on either 120 or 240 vac, please check your power supply!
    15362
    Looks good but still not the at 1% if your wild leg is 255 then you are around 6.7% no point in showing something that others can't have or likely to achieve, but still in reality is no better than a CNC rated RPC
    Mactec54
Page 1 of 2 12
  1. Replies: 34
    Last Post: 08-17-2021, 07:16 AM
  2. 110v VFD, 220v, 1 phase, 3 phases - I'm kind of lost
    By Biggs427 in forum Spindles / VFD
    Last Post: 06-16-2017, 02:52 PM
  3. Bridgeport R2E3 delima, 220v VFD 3 phase Versus 220V Single Phase
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2015, 04:01 AM
  4. Replies: 2
    Last Post: 06-20-2014, 05:24 AM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
