586,058 active members*
3,393 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Issue With Text In Alphacam 2012
Results 1 to 15 of 15
    May 2019
    8
    Exclamation Issue With Text In Alphacam 2012
    How can I get alphacam to stop doing this? I designed this is alphacam for mothers day, and I keep getting these circles on the letters. These circles scale porportionally with the bit size too. currently a 1/8th inch bit.
    May 2019
    8
    Lightbulb Re: Issue With Text In Alphacam 2012
    Here is the picture of what is happening.
    Aug 2014
    19
    Try to upload a zip of the ard
    May 2011
    108
    depends of the text-font I assume?
    May 2019
    8
    It does this on all fonts except the stencil font.
    May 2011
    108
    How are You machining this? Pocketing or Rough/Finish?
    May 2019
    8
    I am Pocketing and Rough/Finish
    - - - Updated - - -
    I will try that today, I will see if it works. Thank you.
    May 2019
    8
    Here is my settings, it is still making the little circles that branch off the text.
    Attached Thumbnails Attached Thumbnails Capture 1.jpg   Capture 2.PNG   Capture 3.PNG
    May 2011
    108
    I would like to see Your AlphaCAM drawving - with toolpaths.. maybe I/we can't se the problem, and it can be right under our noses :-(
    May 2019
    8
    Here is what i've got, the simulation is fine, so I do not know whats wrong.
    May 2019
    8
    Pocketing
    35538
    Are you using G41/G42? If so, try without it.
  1. alphacam to mach3 issue
    By edz_86 in forum Alphacam
    Last Post: 04-25-2017, 09:48 PM
  2. Help importing text from AutoCAD to AlphaCAM
    By ruga666 in forum Alphacam
    Last Post: 06-03-2016, 01:35 PM
  3. Alphacam settings issue.help?
    By DellaRosso in forum Alphacam
    Last Post: 03-13-2015, 09:09 AM
  4. RhinoCAM 2012 issue (not posting correctly)
    By sdantonio in forum Rhinocam
    Last Post: 03-25-2013, 03:34 PM
  5. Alphacam Router Z value issue
    By celtic1967 in forum Mastercam
    Last Post: 09-18-2011, 05:51 PM
