586,111 active members*
3,346 visitors online*
    JOB STOPS RUNNING WHILE ROUTING
    I hope I am explaining this correctly:
    I have been using Planet CNC successfully for several years.
    The last few months for whatever reason the job I am running will stop, the job screen will turn white and lock up. To continue, all I have to do is select the code line where it stopped, right click, and select "continue from this line" and I'm on my merry way. Today while running a job this must have happened 30+ times. A real PAIN IN THE BUTT.
    The only thing I noticed on the screen was the very bottom left corner (I think it's call the Status Bar) was reading numbers like 9780/10,000 and than go blank when locking up. Is this something I need to set in the software?? When I finally got it to work without locking up it was reading numbers like 75/250 but I didn't make any changes.
    I'm using the Vectric application to setup my jobs and have never had a problem.
    Any ideas??
    I seen this as questions on the CNC Zone for a similar problem.
    Which controller do you use? 3/4
    Are your motor cables shielded? Yes
    Do you use external power supply for controller? Yes - Conditioned
    Do you use double-shielded USB cable? Yes - Supplied by Planet CNC
    Jim Markevitch
    Grapevine, Texas
    Re: JOB STOPS RUNNING WHILE ROUTING
    I hope this is the problem. I use a USB drive to copy my PLT files to the laptop in my shop to run my cnc. I thik I had a bad usb drive. Using a new one seemed to cure the problem . . . . . . . .I hope. So far so good!
    Mar 2017
    1312
    So you were reading program directly from USB flash drive?
    Yes I was.
  1. software stops wile running code
    By wtxrcdog in forum PlanetCNC
    Last Post: 05-18-2018, 12:25 PM
  2. Y Axis + Slave not running together when running G-Code
    By Fierra in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2017, 08:56 AM
  3. Gerber 408 motor stops running no error message
    By Comeco in forum WoodWorking Topics
    Last Post: 01-10-2012, 10:39 AM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. Controller Stops Running
    By singingSamson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-19-2006, 09:59 PM
