586,055 active members*
4,399 visitors online*
    Dec 2013
    4
    need help restoring disabled interlock
    The key in the door is installed but this magnetic switch actuator, I don't know where it goes.
    Mar 2007
    2083
    Re: need help restoring disabled interlock
    the part in your photo is the magnetic key to a XCSDMC590L01M8 - Safety Interlock Switch
    Attachment 420180
    I would expect the switch to be mounted on a fixed part of the machine and
    positioned so the magnet on the door can come close to the switch
    xcsdmc590l01m8-user-guide-2-en.pdf3.pdf
    john
  1. Restoring Parameters
    By pmanoj in forum Fanuc
    Last Post: 08-14-2017, 02:25 AM
  2. restoring a lathe
    By Santiago D in forum MetalWork Discussion
    Last Post: 03-29-2013, 06:55 AM
  3. Restoring old SHerline
    By fastpcuser in forum Benchtop Machines
    Last Post: 02-07-2012, 04:55 PM
  4. Restoring an old machine
    By GtownHigh in forum Gecko Drives
    Last Post: 10-14-2010, 12:35 AM
  5. Restoring a BP series II CNC
    By unterhaus in forum Vertical Mill, Lathe Project Log
    Last Post: 12-04-2007, 08:07 PM
