586,067 active members*
5,205 visitors online*
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Jun 2015
    943
    Re: Acorn and Rays feedback
    Quote Originally Posted by Ntl View Post
    You should definitely check it out, it works great doesn't have issues that the others in it's price range have. It will out of the box control a rotary axis (not in development) and it already has smoothing settings that are adjustable and can be saved for different types of machining 3d vs 2.5d (no issues with g2/g3 moves no pausing on direction changes). You get very smooth reliable motion no jerky motion no issues with complex 3d files. It has a spindle encoder for rigid tapping, 2000 line look ahead, touch screen compatible just to name a few features that you might like.
    If you really need more than 4axis you can get one of the higher end boards. Centroid even has true closed loop controllers. Check out the Oak or the Allin1dc the Acorn is just their entry level hardware.
    The thing that made up my mind to with Centroid is the software as well as the support you get. It is professional grade that has worked out the growing pains already. They are also aggressively making the software and hardware better. There's been 3 updates this year and they are very close to releasing the expansion card as well as the Router version of CNC12.
    Dan
    NTL funny guy, no pausing on direction changes?! What the ... ? I thought it requires slowdown and accelerating up for any axis to change direction otherwise your stepper motor would loose step. The acorn does not do any deccelerations and accelerations on direction changes? That's bad.
    Rotary axis is also not in development with mach3, mach4, uccnc, linuxcnc, all support rotary axes and they all support at least 6 axis not 4 only like the acorn and no need for expansion cards, they do it out of the box.
  2. #42
    This thread is about using an Acorn for a lathe. Keep it on topic please.
  3. #43
    Apr 2011
    19
    Hi
    I think I started this thread.
    I was not expecting the feedback I got.
    In my workshop I have a virtual box titled "stuff I do not know". It is large and overflowing. Thanks to the information in the thread, which I have followed closely, the virtual box is still full but no longer overflowing.
    Oh, and I have now developed a plan. I will purchase a Mach 3 licence and see where that leads. If/when I get my head around it, l will follow Gerry's suggestion and using google, download Windows 10 onto my asus and then look at Acorn. My objective is to live long enough to complete my current project list.
    That list cuts out at 99! That is 17 years from now!
    Thanks so much to you all for your information, help and encouragement.
    Woodie
  4. #44
    Sep 2005
    1195
    Is it possible to add driver for 1 more axis on acorn ?
  5. #45
    Last warning.
  6. #46
    Jul 2007
    236
    just read over this thread...and what's missing in the discussion is that Acorn has real Lathe Spindle Encoder feedback! .... that means that the position of the tool is electronically locked to the spindle (when in that mode) so, professional Threading and Tapping can be achieved.
    for instance...during a threading cycle if the spindle starts to slow down due to the force generated by the cut the Acorn closes the loop and knows the spindle position at all times! Acorn slows down (or speeds up) the tool to keep the tool perfectly on target. in my opinion..a critical feature for any lathe. . enjoy!
    https://youtu.be/NjYaWOW1O8w
  7. #47
    1943
    I would like to know exactly why my post was deleted?? I only posted information regarding the capabilities of LinuxCNC.
  8. #48
    See post #41.
Page 3 of 3 123
  1. Acorn CNC PC requirement
    By chris24g in forum Centroid CNC Control Products
    Last Post: 04-06-2021, 02:47 PM
  2. Mach4+ESS or Acorn?
    By HoY in forum DIY CNC Router Table Machines
    Last Post: 11-12-2019, 04:34 PM
  3. Acorn relay board
    By Jknapp55 in forum Centroid CNC Control Products
    Last Post: 01-01-2019, 03:27 AM
  4. Acorn Centroid ATC Macro
    By Chazaxl in forum Centroid CNC Control Products
    Last Post: 02-18-2018, 11:35 AM
  5. Those interested in ACORN
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 08-09-2017, 02:23 PM
