586,100 active members*
2,560 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > 4 axis WTM1325 cnc router with side rotary for furniture working
    Lightbulb 4 axis WTM1325 cnc router with side rotary for furniture working
    Sometimes, our customers want to engrave and cut flat materials,such as wood, plywood, mdf, etc. Also they want to process round or square materials with a big diameter.
    So we customize the cnc router with side rotary, it will be much more stable than a cnc router with a big height z axis.
    Technical Parameter :
    Effective working area 1300(X)mm*2500(Y)mm*200(Z)mm
    Rotart axis Diameter 400mm, working length 2500mm
    Machine Structure More thickness steel pipe welded machine holder bed,
    cast iron gantry
    Working table Aluminum T slot + T-slot table
    Moving type Gantry moving
    Guide rail Linear square guide rail ( Hiwin, Taiwan)
    Transmission Helical rack &pinion for X Y -axis, Lead ball screw for Z-axis
    Inverter Fuling
    Voltage AC 220V± 10%, 50/60Hz, single phase or
    Or : AC 380V±10%, 50/60Hz, three phases
    Driving mode Stepper motor
    Spindle motor 3.3kw air cooling spindle
    Spindle speed 0-18000rpm
    Traveling speed >25000mm/min
    Engraving speed >12000mm/min
    Machine accuracy 0.03mm
    Controller DSP A18 controller, Nc-studio is optional
    Suitable software Artcam, Type3, Ucancam V9,etc
    Running environment temperature 0-45 ºC
    Relative humidity 30%-75%
    Lubrication system Semi-auto
    Tool calibration Auto
    Certificate CE
    Samples show :
    For more information, welcome to contact us any time.
    Jinan Wintek CNC Equipment Co.,Ltd
    www.wintekcnclaser.com
    Email : [email protected]
    Whatsapp: 0086-13678816312
    Re: 4 axis WTM1325 cnc router with side rotary for furniture working
    This machine working video is : https://www.youtube.com/watch?v=5cDuQS9idqI
  1. starting DIY table 4' x 8' and plan on a side rotary axis
    By smithwick in forum DIY CNC Router Table Machines
    Last Post: 11-21-2017, 01:07 PM
  2. BobCAD V28 Mill 4 axis Rotary side milling
    By Primetime93 in forum BobCad-Cam
    Last Post: 05-24-2017, 12:34 PM
  3. 4th axis rotary on the wrong side in simulation
    By metaler in forum Mastercam
    Last Post: 03-09-2016, 02:29 AM
  4. Replies: 0
    Last Post: 04-06-2013, 08:09 AM
