586,052 active members*
4,038 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Work Fixtures / Hold-Down Solutions > Cutting drawer liner material with OTC, Holddown solution needed
    Nov 2011
    16
    I am considering fabricating a small series of partially irregular shaped drawer liners.
    I am planing of using a regular CNC Maschine equipped with an oszilating tangential knife. Coming from the woodworking side of things, machine, OTC etc are less of an issue. But how can I get the material down to be cut? Depending on the material there might be more or less friction. Double-sided tape is not an option I would consider. Any ideas or even better experience?
    Jun 2018
    362
    Re: Cutting drawer liner material with OTC, Holddown solution needed
    A vacuum table sounds like it might be a good option.
  1. Automatic Layout of Cutting Material software and Machine Cutting
    By Roctech-Cathy in forum Roctech CNC Routers
    Last Post: 07-21-2015, 08:48 AM
  2. Cutting silicone liner paper, multiple sheets.
    By benjaminleebate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-30-2013, 05:51 PM
  3. cutting drawer boxes
    By ant818 in forum Techno CNC
    Last Post: 11-27-2012, 01:25 PM
  4. Two stroke c/i liner material
    By Bob Monkhouse in forum Material Machining Solutions
    Last Post: 12-10-2010, 08:13 PM
  5. cylinder liner material help
    By Hiredgun in forum I.C. Engines
    Last Post: 03-07-2010, 01:59 PM
